TAIL LIGHT GASKETS AND DRESS UP
I needed to buy or make the gaskets for the tail lights on my Truck. I found some stuff and decided to give it a go. I also used aluminum " HVAC " tape in the light bucket. I may do the reverse light boxes too before I rivet it back in.
So this is the stuff I found in my garage. It's window caulk and seal. It's like clay except it has more elasticity. I suspected it may make a real good gasket so here's the steps I did to make them.
I nuked the stuff for .30- 1min.
Use wax or baking paper and roll it out like dough.
I used the extinguisher to lightly set the tail light into it. I then used an exacto knife to cut it out.
Finished product minus back up light bucket. Peel paper install lens.
on
Hmm hey good idea those gaskets our not cheap an don't stay in place very good while installing them.
I've used some Edelbrock gasket sealer to hold them in place while in stalling them.
It worked ok.
I see a lot of the stuff you used at the loco flea market for cheap that I'll get some the next time I spot some..
Orich
It worked ok.
Orich
It worked ok.
Orich
It worked ok.
Orich
69 f250 project help
Hey guys I have a 69 f250 360 it is bone stock at the moment I want it to be a daily driver it has the cast iron intake and the 2 barrel carb what would fit I want the intake to be a 4 barrel same with the carb if I want it a daily driver what kind of efi carb would I need and it has a 4 speed so I need it to cruise at least 80 on the highway What gearing would I need for the rear and what else would I need for it to be a daily driver my max is a 6 thousand thanks
frankcowan
11-12-2013 12:01 PM
