Positive Camber After We Replaced The Kingpins and Radius Arm Bushings
My dad and I replaced the king pins and radius arm bushing in my 72 f100. We didn't replace anything else and now the topside of my tire points outward, which I believe means my ride height is too high. I can't figure out what to do to fix it. Any help is appreciated.
Did you come across any bushings like this-
...and if so did you put them back in as originally installed?
That is a generic picture to illustrate alignment angles. Your suspension is obviously different but the concepts are the same. That offset alignment bushing is for a much later model truck or van with ball joints. Disregard that picture. You're going to need to take a quick photo of your tires to describe what your talking about. Nothing you did should have caused what your describing.
At the time I swapped to a disc brake front suspension on my truck, I had installed a pair of Moog CC808 progressive rate front coil springs. After the parts were swapped in, I had very noticeable positive camber on the front wheels. I drove the truck probably 20 miles or so before I could get it to the alignment shop and they were still leaning.
When I took the truck to the alignment shop, the front end settled out after they got it up on the rack.
Let's try this again.
You have swing axles and pins, correct?
You put pins and radius arm bushings on it and it now has greater POS camber? Did you remove the axles or install the pins on the truck? If removed did you let the suspension settle before tightening the axle(s) pivot bushings/radius arm bushings down? You may have seized axle pivot bushings or they do not have enough movement due to tightening in a dropped position. How is the trim height of the truck?
Regardless, it needs to go back to the shop for proper diagnosis.
There, I think I can go back outside again...
Last edited by KULTULZ; 07-12-2017 at 05:45 AM. Reason: ADVANCED CRS - SHORT EYEBALLS - HEAD UP A$$
I think you nailed the OP's problem right there. I think he should raise the truck back up off the ground, loosen the axle pivot bushing's bolts, drop it back on the ground, and tighten the bolts back up,
It is difficult sometimes to see what the poster is saying and I also mixed two different replies in my answer...
I need new glasses. Hard to get real COKE bottles anymore...
Sorry about that Steve...
I think you may be right if I remember we tightened the radius arms while the truck was on jack stands. I'll try fixing it this weekend and let you all know if it works. Thanks everybody for the help. I've been getting info from this forum for years while working on my trucks.
