Hello everyone, new to the 6 liter powerstroke recently upgraded from my 7.3. Recently this odd whistle sound started and I can't quite seem to fogure out the cause. At first it only happened if I was going 70 mph and now it will do it anytime it builds more than 15lbs of boost. I tried tightening some clamps and stuff but that did nothing.
I was gonna ask you if you owned an 03, but that is something I have never heard before. Did you check all the pipes? Almost sounds like a leak in one of the pipes, which would explain why it's getting worse as time goes on.
Is the turbo dusted at all? Spins freely with little play?
Was everyone able to play the videos? Im not sure if that sounds like an exhaust leak or turbo issue to me... I tried looking at the boots and everything looks clean and I couldnt see any holes.
I couldn't play the video but when mine started making a strange whistling sound around 15psi depending on weather it was a cracked turbo y pipe. Had to pull the turbo to change it but wasn't too bad to do.
