motorcraft 2150
motorcraft 2150
I just got my 2150 motorcraft rebuilt and have some questions, First the black cap that says lean on it is cracked is that my choke? I have a vaccum choke pull out i think its called, And does anyone know of a adaptor plate for this carb to go from the 2150 to a holley 4 brl port? And is there any diagram for hooking up the vaccum ports or does it really matter? Engine is a 300 six. Thanks
Hmm alright so that is for a hot air tube..where should i hook that up too ? I have a Offenhauser c manifold and EFI exaust.
I went ahead and swapped the old cap to the electric assist one, So i now need to run a wire (probably 14ga?) down to the S terminal on my alternator correct?
-Electric Choke Conversion Kit-
The OEM electric assist may not operate correctly w/o the hot air source. OEM is powered fron the ALT Stator. Follow instructions for kit. Use a relay under the hood if requires BAT VOLT to keep it out of cabin.
This is on a 4.9L carbureted?
Need photos if HI-PO'ed up...
yes it would simpler is always better this is going to be a woods rig so I'm making everything simple
If you decide to go the with the conversion kit, usually (I am only familiar with HOLLEY) the choke asm requires a fresh air source (go by their instructions) so as not to allow the choke spring to over heat and fail.
There are two methods-
Open Air Inlet (screened) And Filtered Air Inlet
Alright I'm considering just doing a manual choke these electric ones are too picky, any recommended conversion kits? Also vacuum line hook up what is the port on the back towards cab under the air filter and should there be a vacuum from manifold to the carb? I got it running but can't acheive smooth 650 idle only 1200 or above
There is (was) a full electric choke cap conversion kit for the 2100/2150/4100 carb. That would eliminate the need for a hot air source. Would that serve you better?
gregcoll001
03-28-2010 11:43 PM
bronco-man
01-30-2008 09:31 PM
drago5451
06-14-2006 10:16 PM
ctietboehl
02-18-2005 11:20 PM
