2013 f150 eco, Brake job fail.....
So I had warped rotors on our 2013 f150 ecoboost. It was bought new, now has 65,000 miles on it. Had the rotors turned and put it all back together with new pads.... then I had a soft pedal that would slowly go down to the floor, huh? Dang it wasn't doing this before. Oh well I thought must have ruined the master cylinder so I bought a genuine Ford master cylinder and replaced it and the pedal still slowly goes to the floor...What the heck is going on???
Any help would be appreciated
You've got a leak somewhere.
Spray everything down with break cleaner and look for damp spots.
Did you disconnect the hoses when you did the pads? Those copper crush washers can be a bear to get sealed back up sometimes.
Go back through everything you touched, step by step. The only way for the pedal to sink is for fluid to leak somewhere, either internally or externally.
is it possible that you have a weak or damaged brake hose?
if the hose is bulging when you press the pedal it could present as a sinking pedal.
seems unlikely, though.
did you make sure to get the inner and outer pads correct? I ask because they look similar and many have made that mistake. I'm doubtful that this could cause your symptom, but if the caliper or pins are bent, or are bending under pressure I could see how it might cause a sinking pedal.
again, doesn't seem very likely.
I'm about out of ideas ... this is an odd one.
hard for it to act like a leak without it being a leak. I understand why you replaced the master, but I've bled the holy heck out of brakes before and never ruined a master - just seems unlikely that you ruined one and then replaced it with a faulty one, though this is how you describe the problem .... I'm about as confused as you.
Chronic problem
My 2013 XLT 4x4 has the 'sinking brake pedal' too. It started when I two-footed the pedal un a steep grade. Replaced master cyl with a Raybestos. No help. Replaced with a NAPA rebuilt. No better. Paid the $ and got a genuine Ford. No better. Read about the ABS fix and replaced the ABS with a junkyard piece. Took it in to my trusted independent garage, where he did a quick hot-box evaluation and said he would need to do an in-depth. He replaced a switch in the ABS module, yet continues to get a bad signal from the Body Control Module, as well as dashboard faults. Ford is well aware that this is a chronic problem, they don't have a fix and they are stonewalling owners.
The dealer service depts will replace EVERYTHING (m/c, booster, complete ABS, BCM and reprogram) and end-up in the neighborhood of $4,800.00. And still no recall, no service bulletin, no customer concern. Yes, I'm disgusted.
UPDATE I did a mix/match on my ABS module. The scrapyard unit had bad electronics, but serviceable valving. ( not perfect, but close) After installing, I did several bleed rounds, then my independent garage used his reader to cycle the ABS to bleed the air. The pedal is hard at first, and stops the truck easily, but if I'm stopped on a steep hill, it will fade somewhat.
subzero32
09-21-2016 06:35 AM
