Cheap accessories you've added
What are some of the cheap accessories you've added to your truck that you were glad you did. I've only had my my truck for a few weeks so I haven't done much. Put the DeeZee tailgate assist on yesterday. Next up is the SEIC mod. Still debating on whether or not I want a fixed idle or if I wanna install the pot for a variable idle.
This is the ELM327 adapter I use with laptop. It allows access to HS and MS bus on the Ford products.
ELM327 USB V1.5 modified for Ford ELMconfig CH340+25K80 chip HS-CAN / MS-CAN | eBay
You might check to see what is a good bluetooth adapter if you plan on using a tablet or phone. Have not seen any with the switch for MS bus access.
SEIC mod
DPF% Screen using Forscan
EGR Bug Guard
Bull Ring Stake Pocket Inserts
Husky Floor Liners
UVS100 Custom Sunscreen
Items I have purchased but not installed yet
Rancho 9000XL Shocks
Pop & Lock Tailgate Lock
Fumoto Drain Valve
3M Clear Vinyl tape (help prevent rock chips along the rocker panels)
3M Clear Door Edge tape
Future Upgrades
Paragon Bed Cover
Mishimoto CAC pipe
EGR Bug Guard
Husky Floor Liners
Fumoto Drain Valve
Future Upgrades
Paragon Bed Cover
Mishimoto CAC pipe
This charger can stay in the outlet in the dash even when closed.
my truck came with weathertecs but I'm not a fan. They are too hard and slippery. Makes it difficult to get my wallet out without slipping. Also makes it difficult to clear a path after eating a bunch of Mexican food.
I'm gonna be getting some huskys as well.
Received 6,680 Likes
on
I wouldn't call it cheap but I had ClearBra installed by a professional. Just about any leading surface that could get hit by a rock got covered. The tailgate has 6" on the top and 6" on the bottom.
The mod that will save me the most time is the Fumoto Drain Valve.
I won't take a vehicle into the mountains here in Colorado without a set of WeatherTech floor mats.
I'm really, really trying to not do much in the way of modifications to this truck. I did too many mods to my last truck and I just got tired of it.
