Welcome to the forum. This has been discussed many times; I suggest using the search function. If you go to the Advanced Search section, you can filter your results to just this sub-forum.
No rubbing at all... I will be honest though.... I will never hard core off road with it..it's been down gravel roads that were horrible...too much money ...that's what I have 4 wheel drive ATVS for..... I would think if the width is the same as 18s and hieght is no more than 34" it would probably work
Thank you so much for the information! Yea I'll never go hardcore offroading in my truck. I agree, too much money to go and beat it up. I have 32s now and with my 2.5" leveling kit, I know it's gonna look wierd without larger tires. Thanks for the information on this. I knew 33s could clear so I'm glad I know I can go to 34s. 35s would be nice but too much trimming is required.
Yea u just measured my tire and it was about 31" so I'll gain 2.25" which is awesome!
did you get a 5th tire for your spare seeing as it is a different tire size? Did it fit in the spare tire spot underneath the bed?
I'm somewhat interested in a response to this as well, but there are some threads floating around where this has come up and it seems like most (?) people running a 34"/35" tire just count on a tow if it gets so bad that a portable compressor, etc., can't get you to a tire shop.
(Note to self: still need to buy a portable compressor)
Yea I definitely don't want to do that at all. Here's a picture of my spare. There's just a metal sheet in the way that can be cut or bent back. But I'm curious what he did.
Fantastic!! Thank you for the pic! Im glad I can squeeze it in there without any issues.
I finally, after weeks of searching have figured out how big of a Tire I can go. Thank you so much! I will have to post a picture after I get it done!
