460 swap pulleys for alternator only ?
Old 05-28-2017, 11:16 PM
Drlittle's Avatar
Drlittle
Drlittle is offline
Hi all !! Swapped a 1977 460 into my 1978 F-100. Question is about pulleys. The 77 460 had p/s, a/c and all I need is alt. So after removing the a/c and p/s the alt. pulley doesn't align with water pump ? do I Need to get a different pulley for alt. ? or should I just put spacers on alt. bracket to move out to align it with water pump pulley ? Thanks for help
Old 05-29-2017, 04:36 AM
Shortbox4x4's Avatar
Shortbox4x4
Shortbox4x4 is offline
The alternator runs off the pulley groove right next to harmonic balancer on the original set up. It doesn't go around the water pump pulley originally. On a truck that had ac/ps etc... The middle groove did the water pump and ps and the front groove(closes to fan) did the a/c and water pump). If your truck doesn't have power steering? Your going to have to either space/shim the alternator to line it up with another groove or make or find a new crank pulley to make it work.
I pulled a '77 460 out of a camper special and put it in my '77 Shortbox 4x4 but mine had power steering so I had no issues.
Not sure but you could check with CVF Racing for a pulley set up. I've used them in the past.
Later, Shortbox4x4
Drlittle
06-05-2017 11:34 PM
Blown 331
17
08-22-2016 12:49 PM
rangerottis
02-26-2014 11:27 AM
mikefender
12-10-2010 07:44 PM
Quick Reply: 460 swap pulleys for alternator only ?
