Window molding removal?
don’t you have to remove the mirror in order to remove the front?
i am doing just the opposite, going from black to chrome
They can be saved depending in how you pull them off.
2 torx screws holding the outer belt molding. One on each end and 4 long clips that can break, holding it to the top of the outer door.
the mirror does not need to be removed just lift the molding up after you unclip it and slide it back. Just make sure it won't rub on the exterior door paint, the belt molding ends can scratch. Sometimes the front moldings bend and become damaged since they are long and the clips hold it down.
