Need Number Dummy's help please
Old 05-22-2017, 08:53 PM
BeauF0RD's Avatar
BeauF0RD
BeauF0RD is offline
Do you have a part number for the front brake line coming off my brake reservoir of my 1976 f100
Old 05-22-2017, 08:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Ford didn't sell the hardlines over the counter. In the catalog is the note to make the new line from bulk line and new fittings.
Old 05-22-2017, 09:14 PM
BeauF0RD's Avatar
BeauF0RD
BeauF0RD is offline
okay, so I have to bend the circles into the brake lines myself?
Old 05-22-2017, 09:38 PM
kegger66's Avatar
kegger66
kegger66 is offline
not difficult - I read a recent forum post here where an FTEr used an aerosol can (krylon?) to assist with making great circles.
Old 05-22-2017, 10:05 PM
boingk's Avatar
boingk
boingk is offline
I'll confirm that its not too hard to bend these things, just take it slow and watch for any sign of the pipe crimping. If you need to do a radius it always helps to have something on the inside, and a spraypaint can is the perfect minimum diameter.
- boingk
Old 05-22-2017, 10:07 PM
kegger66's Avatar
kegger66
kegger66 is offline
... and get NiCopp line (easier to work with than stainless, won't degrade like regular stuff) to make your new lines with.
Old 05-23-2017, 10:09 AM
BeauF0RD's Avatar
BeauF0RD
BeauF0RD is offline
Thanks guys for the info. And tips, I really appreciate the help.
Old 05-25-2017, 03:04 AM
76f350spercamprspeal's Avatar
76f350spercamprspeal is offline
I just did this on my '95 F150, and it was very easy. (Even for me)
Bleeding the brakes afterward was harder.
Tip: use 1 Person bleeder screws, they have a 1 way check valve and make it easier to bleed your brake. They are $12 for 2 of them.
You can also use a pipe bender or a glass soda or beer bottle.
It looks like this.
Old 07-02-2017, 09:28 PM
BaltoMoJoe's Avatar
BaltoMoJoe
BaltoMoJoe is offline
well, I gotta ask...why does the line need to be coiled ???
Old 07-02-2017, 09:37 PM
BaltoMoJoe's Avatar
BaltoMoJoe
Kegger66, is this Nicopp line any good to replace my Trans Cooler lines? or could this be too soft for being so close to the bottom, you know like things hitting underneath.
Old 07-02-2017, 11:37 PM
kegger66's Avatar
kegger66
kegger66 is offline
I think it will be just fine for the trans. If you want some insurance you can slide some gravel guard over the line (check my other post for a reference from UltraRanger about where to get it - https://www.ford-trucks.com/forums/1...nput-side.html)
Old 07-03-2017, 01:26 AM
meangreen92's Avatar
meangreen92
meangreen92 is offline
Because the master cylinder is attached to the cab, and the brake pressure differential valve is attached to the frame. When the two structures flex and move around somewhat independently, the brake line gets stressed. The coils are there to provide a large section of line to 'stretch' and 'compress' when needed.
So with the coil, the stresses and fatiguing are distributed over a larger area, which adds longevity to the line.
I forget what I used to make the coils - I couldn't find the post...
Old 07-03-2017, 04:01 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Talking
To prevent vapor lock...
...OK... I'm going...
Old 07-03-2017, 09:21 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Jackford
07-14-2022 06:09 AM
Thewishkah
08-04-2019 09:36 AM
460 FORD MAN
13
09-14-2012 01:05 AM
WVMama78
09-09-2009 08:34 PM
pdqtimetrialer
05-11-2006 08:18 PM
Quick Reply: Need Number Dummy's help please
