Bliss and towing question
So I use the display and set up my trailer(s) with owners manual in hand. It is within the size limitations for BLISS (26' long, 8' wide). I have no problem clicking the OK's. I am in tow/haul mode. Seems like all should work. When all said and done, no BLISS.
What am I missing?
What am I missing?
when you selected the type of trailer did you select gooseneck or 5th wheel? Bliss gets turned off for those "type" of trailers. I cannot advise something possible dangerous as there may be a reason Ford did this, but I just programed my 5th wheel a standard trailer. I haven't gotten over 100 miles to start towing it yet, but just testing it the disable icon didn't appear. Now, when I go to tow the 5er, I might find I get false readings due to the overhang of the trailer, but we'll see when that time comes...
I know this is an old thread but did you ever resolve the Bliss issue? Mine was working fine until this last trip. Left Austin Texas and drove to North Carolina, it was working fine. From North Carolina to Florida it stopped working. Keeps telling me I don't have a conventional trailer setup. Nothing has changed with my trailer setup. Tried deleting and re-adding, still, doesn't work.
I experienced issue also. In the trailer menu all was set and selected correctly yet no bliss. In my case I found the menu to the full right, settings or some language like that, there was a check box selection for trailer blind spot. This arbitrarily unchecked itself and still does. Check that setting.
I have the same issue. I've pulled my travel trailer a few times and it worked great. The last trip home I had a message " no conventinal trailer connected" The trailer set up had not changed. I changed the setting to fifth wheel and back to conventinal and it made no difference.
Thanks, I just checked mine it is was unchecked. Drop my trailer off at the dealer for some warranty work so can't check if that will fix it but hopefully, that was the problem. Thanks for the help.
