Did you change Tires and/or Wheels? Post your info here
Lot of talk and great pictures of Leveled and Lifted 2017 Super Duty trucks.
If you've changed your tires and/or your wheels, please post:
* Tire size
* Wheel size & offset/backspacing
* Level kit or lift if you've done that
* Pics!
This will help those of us who are looking to do the same.
Thanks!
* Tire size
* Pics!
Thanks!
Because 11.5 wide tire is designed with 8 in rims in mind Ford use and bases there tow / haul numbers on a 8 in wide rim and it requires certain tires with a certain load capacity to achieve there towing numbers. If you put a 12.5 wide tire on a rim that is technically to small for the tire then towing capabilities drop below design parameters that are apart of the truck when it's left stock.
Tires Plus did mine. Ford can void any of there factory warranties if they choose to on any truck that has been modified or changed from factory stock specs. That includes different wheel and tire size also. If you put in any fluid anywhere other than ford recommended stuff. It could void warranty. If they want to be ******. So I don't think it's any different for just changing tire size. I just like the look and it rides better then factory. But I'm not worried about it. But it a good point.
"Hey, we didn't sell him the tire. He just paid us to mount them."
