1990 E350 w/460 oil pan removal.....
I need to remove and repair the oil pan on my 1990 E350 motorhome with 460 engine. Can I remove the pan without completely removing the engine from the chassis? Can I raise the engine enough in the frame to get the pan out? Anyone done this procedure? Any relevant advice is greatly appreciated!
Thanks......
Thanks......
Looks like the pan has taken a hit from underneath...the sump is caved in/up about 3/4"....not really sure if I need to fix it, but if I can just lift the engine without removing it, I might try and fix the pan.
I've seen worse than that that ran for years with no issues
Having said that, the clearance should be 3/8ths to 1/2"
If you want to fix it right, pull it
if you want an easy fix you might be able to spot weld it and pull it down after you drain the oil, like they do in body shops
how is your oil pressure?
Oil pressure seems good. Motorhome only has 60k kms (40k miles) on it.
Greg Vaughn
02-02-2010 11:16 PM
kp
05-03-2000 08:42 AM
