Amazon CPS?
Amazon CPS?
I recently got a check engine light for the CPS, and I have carried with me over the last two years this CPS from Amazon (Genuine Ford F4TZ-12K073-C Camshaft Position Sensor) - .
The old one I took out was tan / gray in color. Is the CPS in the link the "good" one? Could this affect fuel mileage?
Thanks!
Thanks!
I recently got a check engine light for the CPS, and I have carried with me over the last two years this CPS from Amazon (Genuine Ford F4TZ-12K073-C Camshaft Position Sensor) - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
Thanks!
Thanks!
This one is dark blue, wiht a purple o-ring.
Genuine Ford 7.3L Diesel Cam Position Sensor (CPS) - Blue
Some people say it runs better then "correct" part for the '99-'03. Some people can't get it to run right at all with it. I don't remember if I tried one of these or not.
The "correct" part# for '00-'-03 7.3L is F7TZ-12K073-B
This is the grey CPS, with purple o-ring.
I know that the grey one is the "current" Ford part, sold by the dealer for '00-'03. Maybe Diesel O-rings is saying that it will also work in the OBS? Or maybe its a typo?
I don't know what the actual difference between THESE 2 CPS is. I know some guys have used an International CPS intended for a DT466, because it advances the timing when used in a 7.3L/T444e. I know, from prior reading, that the PHYSICAL difference is that the magnet inside is slightly off-center on the DT466 CPS, which causes the change in timing when used on the 7.3
Advancing the SOI (Start Of Injection) like that gives a little more power, makes the truck louder, and just might up the fuel economy - a tiny bit. Problems would arise if you were to combine the DT 466 CPS with a chip. The chip may or may not advance the SOI already, and the combined effort to advance SOI could take you into dangerous territory - that place of scattered oily block parts.
Well, it looks like the Amazon part number I ordered a couple years ago, is the same one Clay has listed on RiffRaff for 94.5-03, that is exactly what is called for on my 2003 Excursion. The one I took out was gray/tan in color, and the one I put in is dark blue.
I found this from reading on Diesel Orings site - "Some owners of the 1999 - 2003 have found that using this CPS on the newer models have been able to eliminate the cylinder contribution error on cylinder #3 that the gray CPS will cause on some engines."
I am going to contact GearHead and see what they recommend based on running their tunes on my Hydra.
Follow up to the Amazon CPS replacement: I am throwing a soft code again for CPS in under 4,000 miles. I am wondering if this might have anything to do with running LED fog lights wired into my stock fog lights? What makes me think this is when I have the radio on, and I turn on the LED fog lights, my radio signal gets all distorted. As soon as I turn the LED fogs off, the radio signal comes in clear again.
I am now in a pinch, and am leaving this afternoon to go camping with my travel trailer. What is the best local place to get a replacement CPS sensor? Should I go to the dealer, or does a parts store carry the "good" one?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
