clearance lights/leaks
As posted, had water leak at clearance lights, dealer supposedly fixed, have noticed none of the base of lights are flush with roof of truck. The two outside lights have a greater gap between base of light and roof of truck, than the others, but all have a gap between base of light, and roof of truck. Has anyone else noticed this on their truck?
There have been other threads on this. The lights are flat on the base but mounted on a curved area of the roof. Ford uses a thicker gasket due to this as a band aid. If the lights aren't tightened down enough or the gasket is off center, potential for leaking is high. Not one of the better parts of the 2017 redesign for sure...
It certainly isn't common to have them leak. They just don't look perfect due to the base not matching the curve of the roof. I'd still rather have them then not and there is no way in the world I would have ordered my truck without a moonroof because of a leak fear. My grandfather wouldn't order power windows or locks because he was worried one of them would fail. More gizmos you have, the more potential for failure he said. LOL. I'll take my gizmos and my warranty thank you very much...
Agreed - been through this 7-15 years later with early PSD gens that I have owned...
Took mine in for leaking clearance lights on 4-17. Dealer brought in "seek and seal" contractor to reseal lights. Thanks, and shout out to FormerGunt, who posted on 7-9, that there was tech bulletin out by Ford, on 2-12, that some of these lights leak, and there are replacement lights available. 2 months before I brought mine in for repairs, and dealer didn"t know there were replacements available? Called dealer yesterday, told them I want new lights installed. Will post what happens next. Btw, took delivery on 12-28-16
Well I just got off the phone with my dealer. I am not sure that they are obligated to fix per factory direction. I first spoke with the service department and was handed off to the body shop after they were unable to locate the TSB that details the issue with the roof clearance lights.
The person I spoke with in the body shop stated that he had seen the issue with the marker lamps but was also not aware of the TSB until I mentioned it. I then asked specifically if the shop was obligated to follow Ford procedure if one existed and got the answer that they would compare the two and perform what they felt was best.
