1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What can i do with my 2012 crew cab f250 so i font feel every bump i hit
Old 04-27-2017, 08:09 PM
Estebanmarin92's Avatar
Estebanmarin92
Estebanmarin92 is offline
I just got a f250 crew cab and i know that pick up is mostly used for heavy duty but what can i do to make the truck a smoother ride an not feel any little bump on the road that i hit. Please help
Old 04-27-2017, 08:18 PM
Mike189677's Avatar
Mike189677
Mike189677 is offline
If it has the factory shocks replace them they suck and are likely worn out to boot popular choices here are bilstein 5100's rancho 9000's and fox 2.0's I think there called. But it's a heavy duty truck with a solid front axle it's not going to ride like an air ride caddy or even a f150 but you will be amazed at the difference good shocks make.
Old 04-27-2017, 08:31 PM
Estebanmarin92
Thanks alot @mike189677 ill give that a try. An yeah im just looking for something to smooth the ride a bit
Old 04-27-2017, 08:33 PM
eberlestock's Avatar
eberlestock
eberlestock is offline
The fox shocks and 40 psi in your tires rather than the recommended amount that is enough to float the goodyear blimp!
Old 04-27-2017, 09:18 PM
Fordbronco1995's Avatar
Fordbronco1995
Fordbronco1995 is offline
What size tire and wheel are you running? A larger sidewall height will give you a better ride
Old 04-27-2017, 11:38 PM
DavidT.'s Avatar
DavidT.
DavidT. is offline
Definitely lower your tire pressure, it'll help with the ride quite a bit.
Old 04-28-2017, 03:21 AM
seville009's Avatar
seville009
seville009 is offline
i second that......simplest thing to do.
Old 04-28-2017, 05:31 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
50 front, 40 rear..... air up when loaded.
or buy a NON work truck.
Old 04-28-2017, 08:02 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
put Michelin 17" tires and rims. max air the tires will hold. replace the all (front and back)shocks with blistiens, see if you need rear anti sway bars.
Old 04-28-2017, 06:39 PM
thomabb's Avatar
thomabb
thomabb is offline
500 lbs of sandbags in the bed will smooth things out.
Streetgliderr
11-21-2015 12:36 PM
FordTruckChuck
1997 - 2003 F150
19
02-14-2015 12:16 AM
GreenBean94
13
12-07-2011 02:59 PM
DIXIEDOG1
03-20-2011 01:34 PM
Quick Reply: What can i do with my 2012 crew cab f250 so i font feel every bump i hit
