No, it's going in tomorow, hope it will be OK to start. I checked the oil, it is brown and no sign of any coolant, it is also at full mark. The oil cap is kleen as a whistle.
If/when you try to start with starter and assuming batts,connections good if it turns a little and just stops might have coolant in cylinders just so you know and need to pull glow plugs at that point.
Update: Just installed the starter and it started fine, a little bit of blue smoke, did not seem to smeel like coolant. I was probably low when I left it 5 months ago. I add 1/3 of a gallon and it showed up in the reservoir.
One thing, when I removed the reservoir cap, before I started it, there was some pressure left in the reservoir, even after 5 months sitting, what does this tells me, not loosing through the head?
