F250 vs. F350
Otherwise identical? The best I can figure out, it comes down to three items:
1) The F250 with the 6.2 gas engine is fitted with the six-speed Torq-Shift G automatic transmission (aka 6R100). The F350 6.2 is fitted with the 6R140 AT (gas version). Models equipped with the optional diesel engine both get the 6R140 (diesel version).
2) Labels. The highest F250 GVWR label is 10K lbs, which is also the lowest GVWR label (artificially so) for the F350.
3) The rear springs, and even that's not totally clear (to me, anyway). Specifically, it looks like a base F250 is fitted with three-leaf rear spring packs, and the base F350 is fitted with four-leaf packs, but I don't understand note (6):
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Depends on configuration. It's been hashed out a lot here. If you search, you'll find many threads. The closest a 250 comes to a 6.7 SRW 350 is if it has the HD Tow package. Between those two, the only difference is the spring rate of the main rear spring pack. Drop that or go to a gasser there are other differences. You'd have to tell us your exact configuration for someone to tell you all the differences.
F350 has a helper spring to take the extra payload. There was mixed responses on whether the f250 has 2" blocks or if they have the 4" that the F350 has.
Besides that, identical frame, axle etc. And then there is the legality of the F250 only being able to have 10k GVWR.
As to the helper springs, the 250 can have them too. They come with the camper package and the HD tow package on the 250.
For 11-16 they could be ordered 100% identical with the camper package on the 250 as long as it shipped with the 4" block. This started happening in 2015 sometime on the 250's but not in all regions. There has never been a rhyme or reason on that one...
HTH,
Jim / crewzer
I'm talking 2017 models, crew cab, 4x4, short box, gas engine.
In building them online, I think I'd select the "camper package" for the F250 because it's cheap and has more heavy suspension. But, if the standard F350 is the same thing, that's an option too.
We used to have special license plates for 10,000+ GVWR trucks, but I think that's done away with now.
I wonder why the F350 gets a transmission with "taller" ratios? That seems backward.
A nice thing abut the F350 is that you can get the heavier rear springs without having the get the camper package's stiffer front springs should you not want them. You can add the rear ASB later if you wish.
HTH,
Jim / crewzer
leeward
01-29-2007 04:46 PM
