Today my filter showed up
Old 04-26-2017, 11:22 PM
Karlow's Avatar
Karlow
Karlow is offline
I thought I was going to be able to install it in place of the cone filter, but noooo. This thing is massive. I have an Air head filter cold air system or something. I'm going to pull it off and the balance of the air box to install the filter. What do I need to install this filter? Its a Donalson B085011.
Old 04-26-2017, 11:48 PM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
It looks similar to a 3357 filter? If it is then you will just need a piece of 4" metal tubing (to act as a coupling) and a couple of hose clamps. Plus removing your aol air box to make room.
Old 04-27-2017, 06:57 AM
HKusp's Avatar
HKusp
HKusp is offline
I think it's the equivalent to the 6637 filter mod that has been popular here forever. You need to scrap the entire stock air box if you still have it and then get a piece of 4inch OD tubing. There are some PVC and CPVC couplers in Home Depot that will work or as Rikster mentioned an old piece of 4inch exhaust will work as well.
https://catalog.donaldson.com/produc...2974073#tabs-2
Old 04-27-2017, 07:38 AM
00Dave's Avatar
00Dave
00Dave is offline
Yep. I went to an exhaust shop and asked for a short piece of 4" and they gave me a scrap piece. Works perfectly.
Old 04-27-2017, 08:06 AM
F250_'s Avatar
F250_
F250_ is offline
I used the pipe adapter for a while, but now i just use a wood rasp to roughen up the exterior of the plastic connection nozzle on the filter, and then I stretch the rubber intake tube over the plastic nozzle and clamp it tight.
Old 04-27-2017, 11:51 AM
Karlow's Avatar
Karlow
Karlow is offline
Just a straight piece?
Old 04-27-2017, 11:57 AM
F250_'s Avatar
F250_
F250_ is offline
Yes. Straight. 4" diameter, about 4 inches long.
Old 04-30-2017, 03:48 PM
Karlow's Avatar
Karlow
Karlow is offline
Thanks
I went HD with my yoyo.
I picked up a coupler for 3" ABS?
It's OD is 4". I just filed off the tit and it was good to go.
I pulled off the top of the air box and the AirRaid adapter.
I zip tied the air temp sensor to a bracket about 1/2" from the air filter.
dalefuji
Air Intakes, Air Filters & Ram Air
11-11-2018 04:52 AM
Marty1965
1997 - 2003 F150
10-08-2014 12:42 PM
pwrstrk97
10-15-2006 11:42 AM
taxabel
10-04-2004 04:48 PM
Quick Reply: Today my filter showed up
