Fuel Filter Question
Changed my fuel filter 5k later than my normal interval... I usually change it every 10k but ran it for 15k this time. It came out extremely black... I'm wondering if I need to spend a day and pull the injectors to go after the O-rings or if this looks normal for a fuel filter after 15,000 miles???
Also found an oily ICP sensor, cleaned it out with electronics cleaner and ordered the sensor and pigtail from riffraff tonight (from past experience Clay will have that to my door ASAP).
Truck is a late '99, has 141,000 miles, I use no oil during my 5k oil change interval and I have almost 35k worth of perfect used oil analysis. Would you pull the injectors and change O-rings???
Yeah... injector O-rings for sure.
As for the ICP sensor, first try cleaning it with electrical contact cleaner and refresh the dielectric grease on the seal. Check if the oil in there returns at a later time. If you experience a loss in power, then I would suggest the OBDII tools link in my signature before moving on to any expensive parts.
I'm 2 weeks out on a day off of work... will it hurt to continue to drive it until I can get after the O-rings? I have a full set of Alliant O-rings sitting in the garage, if it's no bueno to drive with the oil/fuel o-rings leaking my only other option is to drop it at my local diesel shop and give an arm and a leg for labor.
Personally, I would replace the filter and run it for your usual 10k miles then check to see if it is black. You say you are not consuming oil so it could be something as simple as a tank or two of dirty fuel. When I first got my current truck the filter was black but at 10k intervals since, the filter has been honey colored each change.
Then again, I'm from the camp "if it ain't broke, don't fix it....unless it's an upgrade"
As far as the sensor is concerned, you are doing right to replace it asap. Motorcraft only.
Changed my fuel filter 5k too late... I usually change it every 10k but ran it for 15k this time. It came out extremely black... I'm wondering if I need to spend a day and pull the injectors to go after the O-rings or if this looks normal for a fuel filter after 15,000 miles???
just change and drive and don't worry.That's what the filters look like on these things when not changed out regularly. It was probably close to being completely clogged and you are lucky you didn't get stranded, like me 10 years ago. Of course, I learned my lesson and not only carry a spare with me, but also change it every spring no matter how few miles I put on it.
Really?
Do you think oil should be migrating through your ICP sensor?
Mine had crapped out and it was oil free. Replace it and clean the connector if the insulation is still in good condition. If the insulation is breaking down replace it as well. The sensor is not that expensive but getting broke down is.
rednekf350
10-27-2003 06:30 AM
