Coolant disappearing?
ok my truck has needed coolant constantly for 3 weeks straight. I don't see any leaks any where nor do see any puddles of coolant. My truck has been throwing a code P0112 which was the intake temperature sensor. I replaced that clearer the codes but nothing. What could be the issue? I have an 06 f250 6.0 by the way. It has been "bullet proofed" with head studs, new oem gaskets, oil cooler, new ficm, after market cold air intake and the egr has been taken off. I have it tuned as well. Any help is greatly appreciated!'
How much is it using?
If it's a small amount I had a radiator hose with a tiny pinhole that would leak steam when the engine was shut down and the coolant temps climbed.
Didn't leave a puddle or drops and even though I circled the hole when the hose was removed you could not see the hole.
its using about bout two bottles every 3-4 days.
I don't know if you are joking or what....................... I mean I see the party hat smiley, but I still don't know...........The reason I say this is cause its the second time you have posted this type of response in something I have responded too.
