73-79 f100 front end swap...help!!
If you are talking about lowering it, then we can assume 2WD? If so, take a more careful look- it should already have front disc brakes. Power brakes were an available option, so parts are available at the wrecking yard. You should be good if you grab the pedal assembly, push rod, booster, master cylinder, and vacuum line with all fittings and clamps. It may work with less than that, but there were a lot of pedal/ booster combinations and the parts should be cheap. Getting it all will prevent little issues.
As for lowering- I am no help. Mine's a 4x4 so I am going the other way.
The truck has manual disc brakes. I've heard of doing the 03-04 crown vic swap but I wanted to see if there were other options like that available
Yes it's a 2wd
The compatible Crown Vic donor years are 2003 to 2012 (or end of production).
Alternatively, there are IFS systems from Fatman Fab, No Limit Engineering, TCI, Paul Horton Welder Series, and many others.
Buy a 200v welder... a good one. Not some cheap azz POS from Horrid Fright.
Nathan Plemons
06-21-2009 08:04 AM
vajerzy
28
07-27-2003 08:42 PM
