Aerostar Ford Aerostar
Erratic idle
Old 04-24-2017, 06:06 PM
87&97Aerostrar's Avatar
87&97Aerostrar
87&97Aerostrar is offline
Erratic idle
97 shortie. 3.0 245,000 miles.
I've already cleaned the throttle body and the idle air control valve. Throttle position sensor reads 5 volts, good ground, and a smooth voltage increase from idle to wide open throttle and back down.
Which of these codes is most likely to cause erratic idle? Mostly in the morning.
P0340 Camshaft position sensor.
P1443 Evaporative purge flow sensor.
P0401 Insufficient EGR flow.
P0171 Air/fuel ratio is too lean or rich for PCM to correct.
I doubt it's number 1, and number 4 seems too general to be any use.
I'm leaning toward number 3. Seems I read somewhere that the tube from the exhaust gets plugged up.
This started when I disconnected a plug from the blue air bag box to get rid of that beeping. Coincidence?
Any thoughts?
Old 04-25-2017, 11:54 AM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
Your cam sensor is going out, I would replace this before it dies completely before it leaves you stranded. This is where the computer gets its info to fire the coil.
This also indicate a vacuum leak which would also cause the throwing of the EGR flow code and possibly the Evap code.
Old 04-25-2017, 08:03 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
Hot unplugging of PCM connected components can cause false codes and damage expensive PCMs.
Disconnect both battery cable leads and touch them together for 10 seconds to bleed off charge in system capacitors. Dumps volatile stored codes memory, also learned parameters for your systems sensor variations and drive style.
Check to see what codes come back.
Any of those common Aero codes will cause idle issues.
Old 04-26-2017, 09:50 AM
don-ohio's Avatar
don-ohio
don-ohio is offline
I vote vacuum leak with 245K miles. Also,clean the MAF sensor. don-ohio
Old 04-26-2017, 10:59 AM
87&97Aerostrar
If it was a vacuum leak, it seems like it would do it all the time. Last Friday I drove it about 8 miles in city traffic and it ran just fine.
Old 04-26-2017, 11:32 AM
87&97Aerostrar
[QUOTE=93nighthawk;17141855]Your cam sensor is going out, I would replace this before it dies completely before it leaves you stranded. This is where the computer gets its info to fire the coil.
Do you mean the black cap with the three wires? I have an old one from when I had to replace the complete assembly because it was leaking oil up the shaft seal.
I read somewhere on this site that the engine would run even without the cam sensor.
Old 04-26-2017, 09:03 PM
don-ohio's Avatar
don-ohio
don-ohio is offline
Nah,baby,Nah! Vacuum leaks appear and disappear with engine temp a lot of times. Do n't rule out vacuum leaks OR MAF sensor dirty or bad. don-ohio
Old 04-27-2017, 12:59 PM
jetfiremuck's Avatar
jetfiremuck
jetfiremuck is offline
Vac leak . Check vac lines, pcv . May be intake
Old 05-03-2017, 04:55 PM
87&97Aerostrar
Bought some CRC MAF sensor cleaner and sprayed the MAF sensor as per instructions.
Changed the cam sensor with the one I had on hand. Like to never got the engine cover back on.
Replaced the Evaporative Purge Valve. Evidently this is a pretty generic part. Even Walmart sells it.
Seems to be running okay now.
Had the codes checked again. Only one.
P0402 EGR flow at idle fault.
Pretty much the same as P0401 insufficient EGR flow.
This vehicle rarely goes more than 5 miles from the house.
I think I'm done.
Old 05-03-2017, 09:49 PM
don-ohio's Avatar
don-ohio
don-ohio is offline
Hope you got her fixed! Good job! don-ohio
Alvardo Vizcaino
05-27-2019 06:10 PM
crimson080
07-18-2016 09:09 AM
jmustangs60
05-13-2013 10:15 PM
beckman
1997 - 2003 F150
05-17-2012 11:56 AM
delano79
08-30-2011 08:36 PM
Quick Reply: Erratic idle
