cruising
Old 04-24-2017, 05:30 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
cruising
I know this is the wrong place but I know you guys better and you appreciate this more. I got my 59 F250 together and have been cruising it around. I haven't driven something this fun in a long time. It's great, easy to drive, runs and stops perfect. But oh, those 4.56s. 50-55 is rumbling pretty loud!! I wish I had a set of the ultra rare 19.5s for it.
Old 04-24-2017, 09:44 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
We need some pics!
Old 04-24-2017, 10:25 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I had just thought 'we need some pics' and I scrolled down and Scott was asking about the same thing...
Old 04-24-2017, 10:34 PM
willowbilly3
I only have a couple, from when I first started on it but the tires about all that's different.
Old 04-25-2017, 01:41 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Fine F250 4x4. But yes, it needs a set of the 71410s. Besides better road speed, they look right on a truck. Stu
Old 04-25-2017, 05:06 PM
willowbilly3
I suppose you might know where there is a set?
I can get 255x85x16 that are about 33", would knock the rpm down a couple hundred. Any conventional tires that get taller also get a lot wider, which I don't want.
The 255s would make cruising rpm at 60 about 2800
Old 04-25-2017, 05:52 PM
truckdog62563
I do, but don't know if they are available to a good new home. Will ask. Stu
Old 04-25-2017, 07:35 PM
willowbilly3
Thanks Stu. I figured if anyone knew about a set, it would be you.
Old 04-25-2017, 07:37 PM
tacomacream's Avatar
tacomacream
tacomacream is offline
Here's one.
Old 04-25-2017, 08:02 PM
truckdog62563
My friend texted me back and they are available. I'll pm you. Stu
Old 04-25-2017, 08:10 PM
truckdog62563
Btw, did my other guy follow through on the Dodge 315 parts? Stu
Old 04-26-2017, 08:19 AM
willowbilly3
All he wanted was the spark plug wire covers and I decided to keep them together with the valve coves and tubes. But thanks for the hook up.
I emailed the contact last night, haven't heard back from him yet.
After doing quite a bit of research I see the 225 19.5s don't gain much height over 235x85x16 and not as tall as 255x85x16. I found some highway 8R19.5 Bridgestones that are a little taller than the 255-16s, but not much. I was thinking they looked a lot taller, like 34-35" tall. Must have been the old 8-19.5s that you can't buy anymore that made them look tall in the pictures. A lot of money for not much gain.
On the subject of old wheels, I have one 17 inch one piece wheel if anybody needs it to fill out a set.
Old 04-26-2017, 09:17 AM
truckdog62563
The down side of the 19.5s right now is the lack of reproduction 8-19.5" traction tires. Considering they were used by all the old 4x4 companies, for both Budd and K-H wheel varieties, there has to be a big market for these tires. Old stock Firestones and Coursers are hard to find and of questionable safety in everyday use. I've asked Coker reps to pass on our desire for them to begin reproducing them.
If you have a one piece 17" I'd like to know more about it, and see pictures. I don't think any were made. Stu
Old 04-26-2017, 09:52 AM
willowbilly3
Hey, and thanks for letting me ramble on about the 59 here in the older section. It just seems like you guys appreciate stock old trucks more. It doesn't stir up much conversation on the 57-60 segment, they seem more into bagging or how to put a crown vic front end in.
Old 04-26-2017, 10:05 AM
tacomacream
This is a special truck. '59 was the first year that Ford built there own F-250 4x4. I first got interested in these when I was a kid. The fire chief had one of these and lived down the hill and across the road from me. When there was a fire call he would hit the road with the siren on, red spotlight with 'fire' on the lens and the big whip antenna bent way back. I thought, wow I want one of those someday!
Quick Reply: cruising
