NO START HELP !!! ...BATTERY?
I have a 2005 f350 6.0 diesel that i am having a no start issue with. I have 2 batteries (federated part # 65 - 775 CA 590 CCA 675 ...batteries died couple weeks ago so he jumped it ...ran fine for couple weeks. Came out of work and it acts fine other than wont spark start...turns over all lights work no codes no faults just now start ??? help ford guys !!!! I pulled batteries first and they registered bad battery at a garage took to place i bought batteries they checked them said nothing wrong but needed a better charge ? when put on machine out of truck they registered bat1 at 12.67v with 640cca after charged 13.08v with 690 cca battery 2 registered 12.70v with 728CCA After charged 12.70v with 668 CCA ...FIRST READING TEMP WAS 58 DEGREES 2ND ATTEMPT 71 DEGREES...DOES THIS SOUND LIKE BATTERIES ARE GOOD NOW OR COULD THIS BE MY ISSUE ??? BAD BATTERIES
Do you have a way to read live data? that way you can look at what the computer is seeing.
the batteries might be good but the CCA seems a bit low but it depends on if the batteries were load tested.
Do not try to run or crank with low batteries, it can kill your FICM very quickly.
Richard
Richard
i thought the CCA sounded low after they had charged them...but i am a chick and guys sometimes get REAL dismissive if a woman asks a legit question about a part without being more familiar with my trucks battery needs i didnt want to get the your just a girl look at the garage so i brought my questions here lol ...(cant see you all role your eyes ) lol
If they are testing CCA really only tells how good the battery is, not necessarily how charged it is.
Federated is not a name knowned by me, but if the label says CCA is 675, the tested numbers are around that. That really isn't great, but they are not 100 down from their CCA target. I'd be using better batteries, but there are so many reasons this diesel can fail to start (by auto combustion, not spark), just working off battery test values isn't going to help. With this motor, known cranking volts is a way better indication if batteries need to get replaced. Then you need a means of knowing the sensor values to troubleshooting can start.
lol i try not to let them bother me ...my father was a mechanic and made sure his girls knew enough to survive in the garage even excel at some areas ...but this 6.0 seems to be overwhelming for most mechanics and garages in our area ...i like to be as informed as possible when dealing with them so they dont see a female and think $$$ lol
If you have a spare laptop you can use forscan (free) and one of these to get all the data you need:
or you can use your phone and an elm327 blutooth (android) or wifi (iOS) dongle
Richard
Keep in mind many regular scanners will not work on diesels.
If you have a spare laptop you can use forscan (free) and one of these to get all the data you need: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Richard
Richard
The battery installed at the factory was a 750cca. Most of us try to use a little higher reserve, an 850.
There is how a brand new 850cca well made battery should test out, it's about 150 above it's cca rating.
Two 850s about a year old with some good workouts. The lower one, I never should have bought but it's what you can be given if you don't ask for the batteries to be tested before you buy them.
And a 750 that is over one years old, despite being fully charged, should not be in a diesel or demanding vehicle.
When we start our trucks cold we draw between 500-600 amps. That's getting pretty close to the full capacity of one of the factory 750cca batteries. That's pretty demanding, getting close to a real battery test.
So in a truck like ours, it's really not a bad thing to spend $10-15 so you can monitor your starting voltage during that most demanding time on a simple device like this. When you drop to 10.5 volts, it's really time to get new batteries. Out trucks become a better battery tester then in some garages or stores.
