I'm having starting issues 6.9 N/A
My 1987 6.9 N/A is getting cranky in it's old age and won't start first thing in the morning or afternoon unless it's plugged in. I've checked the glow plugs and they are fine, they all check good and the WTS light stays on about 10 or 12 seconds. If I have it plugged it she starts right up as soon as i turn the key so i'm not thinking it's the return lines leaking the fuel back to the tank but other than those 2 issues i'm stumped. When i'm at work and it sits for 8 to 10 hours, she starts right up but when she sits over night it's a no start time. With the temps in the 60's to 70's i don't think it's all that cold even with the glo plugs working. I don't use ether when i need to start her, i do use flammable brake cleaner so she doesn't blow, just does a slow burn.
Received 3,102 Likes
on
on
on
If you measured during the g.p. cycle, first 15 seconds of Run, you should actually measure 10V, not 12V. Each g.p draws 10A, and the whole draw 80A, which should lower your battery voltage from 12 to 10. If you still measure 12V, that suggests the g.p. are open circuited, ie > 10 ohms. You should measure 0.5 to 1.5 ohms to ground for each disconnected g.p.
Just check with the dash voltmeter.
[____NORMAL____]
^ --- gauge should read here during g.p. cycle, left of the white bar range, corresponding to 10V
............^ = 12V , no current draw, g.p.'s not flowing 80A, not heating up, bad g.p. controller
[____NORMAL____]
I connected my multimeter to the glo plugs and when i turned the key to on, not start but on, it went to under 12 volts, closer to the 9 or 10 volt but there wasn't a line just open space where i think the "10" would have been then slowly went up to 12 volts. By the Ford voltage gage, it's under the "10 volt" place to start with then slowly goes up.
the easiest way to test glo plugs is with a test light. while they are in the truck. clamp the alligator clip to positive batt terminal. touch the tester to the top of the plug where the wire slips on. if it lights up the glo plug is good. you can test them out of the truck with an ohm meter. you have to have one that reads very low ohms. set it to the lowest setting, then touch the two tester terminals one to each end of the glo plug. I dont remember the exact # of ohms but with mine, if I got a reading, the glo plug was good.
on
