Replaced HPOP O-Rings ran great now won't start
My "non-serviceable" plug was leaking on my HPOP so I pulled it and replaced all the o-rings and the non-serviceable plug with a new serviceable plug. Everything went back as it should, ball under the new plug - let the thread locker set for 24 hrs and re-installed. Truck started after a few times cranking it over once the air was purged from the oil rail. Test drove truck and it ran better than it it was before with no leaks. Turned off the truck to make sure nothing was leaking. Tried to start the truck again and it just cranks and will not fire.
I checked for codes and got none. I just went and cranked it again for about 20 seconds and near the end of cranking I got a CEL with a P1212 "ICP Voltage Not at Expected Level"
Fuel bowl is full of fuel.
The HPOP resivour is FULL to the top with oil to the top. After sitting for a bit the oil level was about 1/2" below the top.
Anyone know what my issue may be? Thanks
I get no smoke when I crank the engine and with the P1212 fault code I am guessing it is the IPR. Took the IPR out and the inner o-ring looks ok. The split ring above the o-ring has a small nick in the side opposite the split. Maybe the o-ring is just worn enough to produce a no start no pressure condition? Maybe the whole IPR is not functioning?
Checked the oil level right away. Had just changed the oil while doing the HPOP. HPOP oil reservoir at it's normal level. Drained it again to pull it off and make sure the drive gear was still properly attached to the HPOP and torqued properly. Oil clear and fresh from the oil change - no glittery confetti.
The only thing I can think is the o-ring and split ring on the IPR is not sealing. While the o-ring looks fine it is 20 years old. All the rest of the o-rings on the truck are failing. I replaced them all in the oil cooler not more than a couple of months ago. These are the only parts not replaced when I re did all the o-rings and replaced the non-serviceable plug. I ordered an IPR o-ring reseal kit this morning. Hopefully this is all it is.
I'm still looking for other causes just in case. IPR gone bad? Strange that it would run so well, idle perfectly while I checked for leaks then not restart after shutting it down for a few minutes...
Update:
Got the new o-rings installed on the IPR. Put everything back together and got sputtering and smoke. Figured air needed to bleed out of the oil rail. Cranked on the starter a few times and it would almost catch, sputter but not fire. Tack was moving. Pulled codes - not sure all of them were cleared from before. This time I had a P1661 again, P0344 and a P1212. The P0344 told me it was missing from the CPS sensor. I replaced it with a new one and it fired right up. Took the truck out and warmed it up, ran great again. Figured I fixed it. Parked back in garage and let it sit for 15 minutes. Checked the codes and there were none. Went to start it again while hot - nothing just cranks over, no smoke no nothing - tach is moving. I have two new CPS's so I switched them out again just in case. Same thing just cranks over and there is no smoke. Frustrated!
What would cause the truck to start originally when cold but no start and no smoke when hot?
