ignition coil resistance
I have a 1974 f600 with a 361 my son & I are trying to resurrect. It sat for who knows how many years in a field. At this point we are only replacing parts that will get it started. Once it proves itself, then we will be more giving to it.
So far we've replaced the starter, plugs & wires. It almost started but didn't & now it just cranks. It appears to be sparking but I'm thinking its a weak spark. I want to test the coil next.
Does anyone know what the resistance would be to the coil?
If I do need to replace the coil, would a coil for a '74 360 from local parts store work with a '74 361?
Thanks,
JQ
Thanks,
JQ
Thanks,
JQ
Thanks,
JQ
Try holding a spark plug a 1/4 inch away from a ground and see if the spark jumps across. If you get nothing then pull the cable that connects the dizzy cap to the coil from the dizzy cap and do the same thing(make sure you put plug back in before hand). If your still getting nothing that's jumping a 1/4inch then I'm pretty sure it's your coil. It might not be a bad idea to check your condenser and points in the dizzy. That seems to be the usual cause of ignition problems.
If it has points, try cleaning the contacts with (very fine) emery paper. Coils go bad at times, but they often get needlessly replaced when the problem is somewhere else. Don't replace condenser with anything but NOS or Autolite/Motorcraft. The parts store sell chinesium and these have proven to be junk. The points are not much better.
If you have a spark at the plugs, the basic ignition system is OK.
A poor spark can be caused by points set too wide (condenser not
having enough time to charge). Set them with a dwell meter. Then
check your timing. Manual method is good enough to start the
engine (points just start to open at 8 degrees). For a truck that has
been sitting for a long period, I first suspect a fuel problem. Old gas,
clogged fuel pump or varnished up Carb.
I'll check the points & go from there. We cleaned out the fuel tank as best as we could & disconnected the fuel line from the carb. We sprayed some carb cleaner into the carb & have been using that "engine starter" stuff to try & start it. Might spray more carb cleaner & let it sit. Not ready to pull the carb yet but I realize that may have to happen. Greatly appreciate the help.
JQ
JQ
Sounds pretty low to me. Have you tried pulling the cable from the dizzy cap to the coil and checking your spark?(leave it plugged into the coil as that's what your testing). It sounds like you may need to get a new coil.
JQ
JQ
billdevaul
02-26-2013 11:09 AM
