Electrical disconnects before welding
05 f350 6.0 diesel, I am going to do some rust repair, A will be mig welding of replacement rocker panels. I know I need to disconnect the batteries, Is there anything else I should disconnect: FICM ? Injector control module ?.Any imput would be great Thanks
I do TIG. MIG, stick, flux welding often on trucks.
run a ground rod into the ground and use a jumper cable to ground the frame close to your weld areas.
disconnect matteries
disconnect (once the batteries are disconnected), the two main connectors to your computer.
TIG would be a better choice for body panels.
