Spare Tire Bolt -- doesn't fit???
I have a '92 F350 and I'm trying to get the spare mounted in the factory spot again. (it was tossed in the bed when I purchased the truck)
I ordered what is supposedly the correct 145mm bolt and retainer for this year and I've measured to ensure it is the right length, but when I tried to mount it comes up short on the wheel retainer. (by about an inch or so)
Trying to figure out what is going on.
Is it possible the wheel is not OEM? It seems to be about the same size as all the others. Was the factory spare significantly smaller or have a different offset on the rim itself? Anybody have a picture of everything on the carrier, but *NOT* bolted all the way up. ie... with the J-bolt removed so it is hanging down - in order to compare.
Thanks in advance
Thanks in advance
Couldn't you just turn the tire over? As it is in the photo it wouldn't lay flat against the tank even if the bolt was long enough. But if you turn it over the tire will go flat against the tank when raised and then the bolt might reach too. Worth a try.
I can find no reference to a different size bolt in anything I've searched, as well as the factory service manuals - which I own. So not sure what to do at this point...
First I need to say that I've never dealt with a spare on a dually. So what I say is from experience with single wheel trucks.
The center bolt and retainer aren't needed. They can be helpful to hold the tire in place on the carrier as you lift the carrier up. But once the carrier is clamping the tire up it won't move without the center bolt.
Also there's nothing that magical about the center bolt. Take the retainer to a hardware store and figure out what thread it is, then buy a long carriage bolt, or even some threaded rod and a couple of nuts to hold it on the carrier.
That said, are you sure that the under-bed carrier works with a dually wheel? On a single wheel the tire sticks past the wheel on both sides, so you end up only contacting the tire on top and bottom. With a dually wheel it seems like you're going to contact the wheel (or the plastic retainer you're trying to get on). I can't picture how that would end up holding the tire very securely. Again, no experience with a dually here, just trying to picture how it might work and I can't.
I was hoping someone on here had a dually with this thing all mounted up that could take a picture or something and show me what is wrong - because as-it-is, its not going together.
