Cab mount rubber bushings.
So I broke down and purchased the 1959 cab mount kit from Carpenter. Sure enough as advertised the mounts do not fit the 4 X 4. Every site I have tried does not have the rubber bushings.
What are you guys doing for rubber mounts on your 4 X 4? Is this a secret?
I need a lead. My cab is painted and on the way.
Restoration specialties and supply inc. I would tell them what you need (1959 ford 4x4 rear round body mount) they should have the size and density on file and will make it. If not you can send your old one in and they will make it. I had 6 made awhile back at a reasonable price. Good luck.
Three phone calls and they were not interested. They indicated they had nothing on file for a 1959 Ford.
Anyway thanks for the tip. I've spent hours on line looking at bushings and think I have found a replacement. I'll spend another $25 to get a first hand look at them. The specs seem 98% the same.
Absolutely no company would provide any help on this one. With a diameter 2.5 inches, height 1.25, hole .75 inch, provided by member idaho211, I located bushings that I think may work. They were made by Energy Suspension but since they were of no help, I purchased them through Jeggs. Part #355-9-4102G. I have not received them yet. I should know later on this week. They are called universal mounts.
