My daughter's 4 year project and counting
Then on to power. Put feelers out to friends for an engine.
Got lucky on a 355 with Turbo400, new rebuild with 20k km on it.
Donor truck '87 chev after ripping all apart
It donated engine, trany, exhaust, rad, seat and various other parts.
Cut frame, put on hitch and poof! Trailer!
Little cleanup
Ready to go
Little cleanup
Ready to go
High compression heads, holley 650
Should go.
After having it sit 5 years, i checked it all out.
Check compression, dry, no oil. Some over 100psi, but a couple cylinders under 60. I though oh no....
So put some oil to losen rings.
Poof! Instant 180psi compression in all 8!
Test run, and engine flush
Should go.
Then major repairs to cab
Repaired floorboards, not rotted completely through, but a few holes.
Design flaw from henry...what could you be thinking? A hole in the wheel well?!
Patches on bottom to close holes
Steering fitment
Double joint linkage to rack
And fit the front clip and fenders on to give me some hope!
Cut out inner wells for ifs towers
Steering fitment
