clutch hydralic line came loose while driving, tryingto figure out the issue
Old 02-06-2017, 07:36 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
Bootlegger's Deluxe is offline
Hello everyone!
Today I am working on my 1993 ford F350, the Stay Puft Marshmallow Truck. about 500 miles ago, i had the engine and transmission out, and when i re-installed it, i put in a new clutch and a master cylinder/slave cylinder combo. it is an internal slave cylinder, I got the one piece pre-bled kit that came with the line and everything (Brute power/ Perfection clutch part # PF9017) and it worked wonderfully. i plugged it together, and i was up and going.
Fast forward to this morning. I was cruising along on my 10 mile jaunt to work, i was about 3 blocks from work, in town, going 30 mph, decided to downshift to slow myself down, and the pedal would not move an inch. i pulled the shifter into neutral, rolled to the stop sign, and a coworker tugged me to the work parking lot with a chain. At the end of the work day, i pushed the truck in, found out that the coupler from the hydraulic line to the slave cylinder had come loose, and must have some sort of check valve on it, because if is not connected, the pedal wont move. So i hooked it up, pumped it a few times, it came loose. I re-attached it a second time, gave it several tugs, and it seems like its secure, but perhaps i am overlooking something?? Has anyone else ran into an issue like this??
Also, from what i have found, gravity bleed is the preferred method to bleed out this system? is there any better ways, or is that it??
Old 02-08-2017, 08:18 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I've never seen anything like that happen before. Does the line appear damaged?
Old 02-08-2017, 10:20 PM
Bootlegger's Deluxe
nope. it plugged right in, i did the super sucky bleed procedure a few times (im hoping the pedal firms up a bit more as i drive it) and i drove it home tonight. i'll drive it tomorrow and give it an inspection tomorrow night.
Old 02-28-2017, 10:48 PM
Bootlegger's Deluxe
the line decided to unhook itself again tonight. this time, it would not re hook up, even as i layed under the truck in the road while it was raining. finally, after half an hour of trying, i gave up and pushed the truck back inside.
before i tug the entire transmission out and replace all the hydraulic parts again, does anyone have any ideas or suggestions??
Old 02-28-2017, 11:30 PM
88n94's Avatar
88n94
88n94 is offline
I'm guessing about all you can try is getting a new line that goes with your Brute Power setup and see if it will stay attached to your slave cylinder. Also make sure there isn't part of the old line broke off inside the slave cylinder, if you can get to the slave cylinder.
Old 02-28-2017, 11:45 PM
Bootlegger's Deluxe
the slave cylinder is internal, you can see the connector poking out of the side of the trans.
here is the kit that i got before. they said they would warranty it.
More Information for BRUTE POWER/PERFECTION CLUTCH PF9017
Old 03-01-2017, 12:26 AM
88n94's Avatar
88n94
88n94 is offline
Yes I remembered the slave cylinder was internal. Beings it's warranted, I would get the line that comes from the master cylinder and whatever associated parts and see if it will plug into the slave cylinder.
Old 03-01-2017, 07:17 AM
Bootlegger's Deluxe
so, your thought is that i should first attempt to just replace the slave cylinder and line before dropping the trans and swapping out the slave. i gotcha.
Old 03-01-2017, 10:09 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I am assuming the brute power piece does NOT have the white plastic retaining clip like the factory piece does?
I am going off memory from my buddies small block when we did the clutch in it
Old 03-01-2017, 01:05 PM
Bootlegger's Deluxe
this system uses an "improved design" that uses a large clip to hold the line in place, similar to what is used on the fuel filters on these trucks, just made of metal and larger. its a great theory, but if it doesnt stay put, then its total crap, i spose.
i talked to the company tech line, they have not heard of this issue before, so lets just hope something was faulty in the manufacturing and that the new one will fix everything.
Old 01-18-2018, 09:48 PM
Bootlegger's Deluxe
Dragging this thread up.
Almost a year has passed, I finally dropped the trans, put in a new slave cylinder, line, and master cylinder, and put in a new clutch for safe measure. Got it together last Saturday, drove it all week.
106 miles in, the line blows off the slave cylinder. I re-attached, and it blew off two more times in the time it took me to get home ( 8 blocks).
Anybody?? Anything??
Old 01-19-2018, 07:25 AM
Redark1's Avatar
Redark1
Redark1 is offline
so i take it that that clip in the rock auto picture is what holds it together. i would have to say its not seating all the way in or the clip isn't completely seating. there has to be something in how the fittings go together and it needs to seat all the way in. kinda weird its happening on your second one.
call the people that make it and see what they say about the fittings being seated together and how to know its in all the way.
Old 01-19-2018, 02:21 PM
Bootlegger's Deluxe
called the company, gave me the runaround. decided its time to find a better way.
I noticed that the line is held in with roll pins, so i found an adapted that will go from the roll pin to an AN fitting. and then run an AN line from the master to slave.
I'll update once i get it done.
chunkyshabutta
11-02-2017 01:59 AM
truckermark
18
03-24-2017 04:56 AM
nacra88
05-15-2016 06:06 PM
jaywall
04-01-2016 04:21 PM
oldblue89
07-07-2012 10:44 PM
Quick Reply: clutch hydralic line came loose while driving, tryingto figure out the issue
