1966 Ranchero Question
Not dumb at all. No one knows.
I would guess it did. You should be able to see up on the firewall where it bolted to the firewall. The one piece and two piece braces bolt up the same I think.
Why is it important? Because it's part of a triangulation design that gives the whole front end enough strength to stay fairly close to it's designed shape.
Fairly.
These things--Ranchero, Mustang, Falcon etc, are pretty flexible and prone to getting whacked out of shape. "Weak" would be another way of putting it.
Fairly.
No shock tower braces in 66
Though I wasn't really clear myself (even though I happen to be president of a FCA chapter) I did a little research and there were no shock tower braces in '66 Falcons - the foundation of the Ranchero for that year. Or, at least, I can not find a single image of one with shock-tower braces.
Though it was still a uni-body car, Ford must'a not thought it was needed, whereas the year before it was needed. The engine bay radically changed in that one year though - allowing for much larger motors than you could shoe-horn into the bay in '65.
Could it benefit from one is perhaps the question. That I can't say for sure, but I think the more torque your motor can make, the stiffer you want things t be.
Hope this helps.
Hope this helps.
The only Ranchero's that have a separate chassis are 1957/59 & 1972/79.
1960/71 Ranchero's have integral bodies, the body & chassis is a one piece welded assembly, w/a stub frame for the engine/trans to bolt to.
Mostly, the 66-70 Falcons were the same as 66 Fairlanes. There were some minor changes to the 67 Fairlanes that got incorporated in the Falcons starting in 67 (dual bowl master cylinder to name one). In 68, the Fairlane changes completely, but the Falcon did not.
So if you are having trouble finding 66 Ranchero Parts (I am assuming you have tried Falconparts.com., Macs and/or AutoKrafters), trying searching for 66 Fairlane or 66 Falcon station wagon parts, as the Ranchero was based on the wagon.
