Actual Gas Tank Capacity/Low Fuel Lite
According to the Owners Manual, the 2016, 6.2L pickup has a 35 gal. tank. However, after the lo fuel warning lite comes on, driving another 15 miles and the fuel gauge showing about 1/8th, 25 gal is all that can be added.
It would seem that if the lite/gauge are close to accurate, the gas tank might be of the 28 gal. size that the "book" says goes in an incomplete vehicle.
Is there any way to be certain what I really have - tank sizes, etc??
Many thanks for suggestions.
Bill
Bill
Actually, it's something else.
The fuel pump has to be submersed in fuel for cooling I think. So what's happening is, the low-fuel light comes on way before you're really "running out of gas".
On my 2001, I ran the tank down to where the low-fuel light was on, before I dropped the tank (pump module retaining ring broke - looked like it was chewed).
I them pumped out about 4 gallons of fuel. which is about right - I can get 24 gallons into it when the light is starting to come on, and it's a 28 gallon tank.
At least your trucks are still checking on the remaining fuel. My Taurus starts complaining at the 50 miles left to empty mark based on the current MPG.
^^^ Its likely this. Many vehicles have fuel pumps that live a longer life if they're bathed in fuel to act as a heat-sink. I've seen some fleets that ran GM vans, and they had a sticker near the fuel gauge that advised their employees to always refuel as soon as the indicator showed 1/4 tank left, because they had been experiencing high rates of fuel pump failure.
Denny
Based on my somewhat limited experience with my 2015 F-250 Platinum CCSB (6,200 miles), I track the calculated miles per gallon and gallons remaining and pretty much consistently come up with an endurance of about 30 miles beyond the distance-to-empty numbers the truck displays. I wouldn't deliberately push it that far, but in a pinch I would be fairly confident in that range.
as for fuel pump....
YES running low on fuel will heat the fuel and overheat the pump.
also Hot blacktop on a very warm day.. and under a quarter of tank can also overheat pump.. while driving down the road....
I have replaced MANY pumps... many become weak. and can not build proper fuel pressure... so the pump can run.. make noise.. but not have proper pressure to run engine. it might start.. but well. just and FYI.
