What is the purpose of a riff raff panel replacement
>is there one other than the ability to have more switches and gauges?
What kind of stuff could an excursion owner need 9 switches for? Or 3 for that matter? And gauges? I saw where one x owner put a phone cradle where there normally go two gauges, would a note 5 cradle fit there?
Extra lights are common. High idle switch. Manually engaging the fan to run faster is useful for people that tow and want to get ahead of heat. On board compressor. Electronically locking differentials. Extra battery isolator relay.
There's a bunch of possibilities really.
Not sure on the size. AFAIK riffraff only has the manual panel available right now, the auto one isn't available and when I checked some dealers it's on backorder with no restock information available which sounds to me like they aren't going to make any more.
I am also the guy who mounted his phone there. My Wilson universal cradle will fit my iphone 6 plus with room to spare, so if you need a bit more room, no problem. I mounted a cigarette lighter there so I could power the phone.
I'll be a supporting member in a few minutes.
thanks for the ideas
please post when andif you find someone selling automatic panels
There is always a need for more switches! I use mine to control more lighting, power inverter, stereo system, and anything else I can think up! Think of it as upfitter switches option for our trucks.
[QUOTE=Peace2Peep;16380613]There is always a need for more switches! I use mine to control more lighting, power inverter, stereo system, and anything else I can think up! Think of it as upfitter switches option for our trucks.
Your page was the first I found when I got my excursion and started looking up things to modify or add.
Excursion didnt have a stock transmission did it? How did you get an automatic panel? was it from riff raff or junkyard or what?
and thanks for the switch ideas. not only is this my first escursion but first diesel and first truck not a 1/4 ton. Except for a 2wd chevy I inherited a couple years ago that I never looked into modding etc.
If you're asking if all Excursions came with automatic transmissions then yes, they all came with an auto.
Stewart
Not sure what you're asking here. I'm pretty sure you meant to use a different word other than "stock" because I know you know that Excursions were equipped with transmissions from the factory.
Stewart
Stewart
Stewart
Stewart
Stewart
