Key in door open chime disable - with pictures!
I hate the chime when the key is in the igition and the door is open. I often have the door open when I'm backing in my fifth wheel or hitching/un-hitching, and it drives me crazy. I searched and found that there are several threads on this - but none I could find with pictures on the process of disabling the chime. So when I did this today, I decided to take some and post it for reference.
There are a couple of methods floating around out there - the one I chose was to remove the key barrel and cover up the copper tab that sense the key. It was REALLY easy - much less involved than it sounds, and I highly recommend this method. I'll post the pictures following, in order of the sequence of events.
Jim
2005 Ford F250 Lariat 6.0L TD
Jim
Last edited by mcwhirtj; 06-05-2016 at 10:07 PM. Reason: Added vehicle information.
This shows a view into the empty key barrel holder/socket, and you can see the little "quarter-moon" plastic piece that you have to remove. This plastic piece holds the copper tab that senses the key. I just gently wiggled and tugged and it came out.
I did the mod a while back where you remove one of the wires going to the key cluster. Only to find out it disabled the headlight chime, and maybe something else... dont remember now.
Any way..... I put it back to stock.
I'll be doing this mod soon. Reps sent to the OP.
