2013 F150 FX2 broken sunroof track TSB help!
Old 02-11-2016, 07:02 PM
mbkowns's Avatar
mbkowns
mbkowns is offline
Cool 2013 F150 FX2 broken sunroof track TSB help!
My sun roof is jammed up and has trouble opening\closing. Looks to be this exact description while visually inspecting it. Ive found numerous complaints about the plastic track system in the f150s so it was likely a TSB was created. The best I could do was the information below and here is what I did so far.
I called the local ford dealers but none of these numbers made sense to them. The wording looks very much like a TSB so I am reaching out to you guys to help me figure this out.
Anyone have any ideas here or access to the TSB system to help search? The problem can be where its listed under 2014 years but applies to my 2013 so searching for it can be difficult.
Here are a few pointing to the same issue without a TSB number that can help but maybe I am missing something useful here.
VISIBILITY:SUN ROOF ASSEMBLY
Date Reported
FEBRUARY 01, 2014
NHTSA Reference
#10055574
TSB Reference
#ASI-44420
Description: FORD: THE ROOF OPENING PANEL FRAME ASSEMBLY NEED REPLACING DUE TO AN ISSUE WITH SUNROOF BINDING ON SOME TRUCKS. MODEL 2013-2014 F150. *PE
Want to learn how to fix NHTSA #10055574?
2013 Ford F-150 TSBs (Technical Service Bulletins) | FordProblems.com
Component Description
Bulletin Number
ASI-44420
Bulletin Date Month
1402
Summary
FORD: THE ROOF OPENING PANEL FRAME ASSEMBLY NEED REPLACING DUE TO AN ISSUE WITH SUNROOF BINDING ON SOME TRUCKS. MODEL 2013-2014 F150. ( NHTSA ITEM NUMBER - 10055574 )
http://www.ownersite.com/tsbs/tsbs.cfm/2014/Ford/F-150/
TSB #ASI-44420
NHTSA ID #10055574
Date Announced:
FEBRUARY 01 2014
Additional Info:
How to Fix
Summary: FORD: THE ROOF OPENING PANEL FRAME ASSEMBLY NEED REPLACING DUE TO AN ISSUE WITH SUNROOF BINDING ON SOME TRUCKS. MODEL 2013-2014 F150. *PE
2013 Ford F-150 TSBs | CarComplaints.com
Old 02-11-2016, 11:06 PM
brokenleg's Avatar
brokenleg
brokenleg is offline
Sounds to me the dealer doesn't want to deal with it
Old 02-12-2016, 08:48 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
Originally Posted by mbkowns
My sun roof is jammed up and has trouble opening\closing. Looks to be this exact description while visually inspecting it. Ive found numerous complaints about the plastic track system in the f150s so it was likely a TSB was created...
Welcome to the forum, mbkowns! TSBs are assigned by VIN, so your dealership would be able to see if a particular service action applies to your vehicle by looking it up by that. How many miles are on your truck currently? I'll see what I can do to help out.
Crystal
Old 02-12-2016, 08:17 PM
mbkowns's Avatar
mbkowns
mbkowns is offline
Crystal
Thanks Crystal I emailed you last night, let me know what you think you can do.
Old 04-10-2016, 08:39 AM
NDJ562000's Avatar
NDJ562000
NDJ562000 is offline
Cool 2013 F-250 moonroof issue
Had the same issue in our 2013 F-250. Same black piece the other gentleman posted a picture of too but popped out on the driver side. Dealer quoted $2200+. Have 33k on the truck but the factory warranty ended on 12/29/15 but I have Premium Care for 84mon and 75k miles. The dealership wanted 3 days with the truck to get "pictures of the moonroof to submit to warranty. If ESP declined it would have cost me $940 just to get the truck back on the road, or $2.2k to fix. I asked the dealer to hold off as I waited some peace of mind the ESP would cover it.
Called Ford customer service and they couldn't tell me for sure what all was covered, then forwarded be over to ESP customer care and they pointed me to the website for the PremiumCARE brochure and asked if I saw the moonroof on there (which I didn't) and she promptly stated only to confirm was to have the dealer go through the full process to see. $940 to remain broke if not under warranty or $2.2k to fix or maybe JUST MAYBE $100 for a warranty deductible.
I've very confused on why no one could say if it would even be covered by my ESP plan, the first lady did tell me switches and motors are covered on the factory 3yr/36k but the track was not so she figured it wasn't covered under the ESP.
Thanks for the thread I'll be watching to see if anyone does the Dr SunRoof fix or gets some traction on what appears to be a common failure in a very expensive vehicle.
Old 07-09-2017, 08:55 AM
Coldbay's Avatar
Coldbay
Coldbay is offline
I have the same issues with my 2012 F250. Anyone have more updates?
Old 04-23-2018, 07:44 AM
DCB12's Avatar
DCB12
DCB12 is offline
Sun Roof Frames
My 2017 F-250 has same issue. Dealer said he had 9-10 F-150/250 with large sun roofs with same problem. Parts on order, back ordered with no known delivery date. Mine will be covered under warranty. Wet carpet with potential mildew issues. Will ask for new carpet but doubful I will get it. Until parts arrive mine is in driveway with tarp over the roof.
Old 04-23-2018, 08:02 AM
Coldbay's Avatar
Coldbay
Coldbay is offline
Lucky you! I ended up zip tying the broken brackets together so the sunroof holds tight into position and then pulled the fuse. Not worth fixing.
Ask for the moon and make Ford pay for anything damaged seen now and possibly later. Make them change that carpet!!!
Old 07-15-2019, 04:17 PM
Manda Alford's Avatar
Manda Alford
Manda Alford is offline
Over the weekend I had opened the sunroof and when I went to close it, there was a pop and the sunroof would not close. When I would push the button to close It would get almost there and then just open back up. I finally got it to close with a little help. Then the husband wanted to look at it and it was even harder to get it to stay closed. It is now closed, but when you are driving down the road you can hear the wind like it is still opened. It seem to be the back part of the window that did not raise up and seal. Would this be the Sunroof Track Assembly? Where would be the best place to order one and how hard is it really to repair?
Old 07-19-2019, 08:00 AM
Siberexpress's Avatar
Siberexpress
Siberexpress is offline
Here is the Part for the Sunroof Repair and here is the Video
03-14-2022 01:24 PM
jeinan3
12-15-2015 10:01 AM
Nightintruder
1999 to 2016 Super Duty
12-08-2010 07:47 AM
ChicoTom000
General Automotive Discussion
04-02-2006 11:20 AM
magnumcccc
01-10-2002 06:57 PM
Quick Reply: 2013 F150 FX2 broken sunroof track TSB help!
