EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
2.0l Ecoboost Swap?
Old 06-17-2014, 09:01 AM
mefast's Avatar
mefast
mefast is offline
2.0l Ecoboost Swap?
It looks like Ford Racing has released a controls pack for the 2.0l Ecoboost. Anyone want 252hp and 270 lb-ft out of a 300 lb engine?
Crate Engine: https://www.fordracingparts.com/m/Part.asp?p=22999
Controls Pack: https://www.fordracingparts.com/m/Part.asp?p=22998
I'm not sure what transmissions will bolt up, but a ZF5 or a Tremec 6060 would be awesome!
Old 06-17-2014, 04:10 PM
Maltman's Avatar
Maltman
Maltman is offline
the 2.0 really weighs 300lbs?? the possibilities are endless...
Old 06-17-2014, 05:58 PM
mefast's Avatar
mefast
mefast is offline
According to Zack Bowman who's doing a swap into his project 'Ugly Horse' on Road and Track's website has it listed at 291 lbs and wikipedia has it at 328 lbs, but no reference.
Old 06-27-2014, 12:34 AM
j.grif's Avatar
j.grif
j.grif is offline
I think this would be a super engine for a locost super seven project!
Old 06-30-2014, 01:26 PM
mefast's Avatar
mefast
mefast is offline
I've seen some posts on Locost forums about this engine.
Apparently with the Ford Racing tune that comes in the control pack, power is increased to 360 lb-ft and 295 hp on 91 octane fuel. Think that would be enough to drive my RWD '95 F150?
Old 07-07-2014, 10:38 AM
heymrdj's Avatar
heymrdj
heymrdj is offline
Let the Ford Ranger swaps begin!
Old 07-07-2014, 01:04 PM
mefast's Avatar
mefast
mefast is offline
It would be a quick and fuel efficient truck if you did. Also, since the 2.0l Ecoboost is based on the 2.0l Duratec block, the transmission should bolt up (I'm not 100% positive on that, but I can't find anything to debunk it yet). I'm also not sure if the motor mounts are the same, but it would be pretty slick if it was. One other thing I want to confirm is if a 2.0l Ecoboost from a Focus/Fusion/Taurus/Escape/Edge/Explorer will work with the controls pack. If so, there will be a bunch of engines already available in junkyards.
Old 09-15-2014, 09:14 AM
mefast's Avatar
mefast
mefast is offline
I still want to swap this engine into my F150, so here's a little more information I've found out. Apparently the crate engine is the same engine found in the 13-14 Focus STs. The head and turbo manifold are slightly different for other versions of the 2.0l Ecoboost, so I doubt the controls pack will work properly with any other version. Transmission options I've found are the M5OD-R1, a T5 with an adapter plater or a 6 speed from an NC Miata. Based on reviews, vehicles with a curb weight of 4000 lbs should get around 23 MPG combined and should be able to go 0-60 in the mid to low 6 second range. In my opinion, that sounds perfect for a daily driven truck.
Old 10-18-2015, 03:32 PM
WhatDoYouGuysWannaDo's Avatar
WhatDoYouGuysWannaDo is offline
Sorry to ressurect this old thread as my first post, but this thread is why I came here.
I've been trying to decide if I want to buy a new 2015 F-150 ecoboost 2.7, or if I'd rather build a 73 - 74 (my favorite 2 years) F-100 with a crown vic front end and a 2.3 ecoboost from the new mustang. I've always liked the sound of 4 cylinder engines more than v6s.
Old 10-19-2015, 11:49 AM
mefast's Avatar
mefast
mefast is offline
Buying a new F150 with the 2.7L would be a lot less work, but what are your end goals? Neither the 2.7L or 2.3L would be a good choice if you're planning on towing. The motor mount locations on the Crown Vic IFS are set up for a modular engine (4.6, 5.0 or 5.4 V8), so you'd need some modifications to make the Ecoboost work. At this time, Ford doesn't offer the 2.3L as a crate engine so you'd have to get one out of a salvage 2015 Mustang or Lincoln MKC. The other benefit of going with a 2.0L vs a 2.3L is the controls pack from Ford Racing.
Old 05-06-2016, 04:21 PM
Phlip_249's Avatar
Phlip_249
Phlip_249 is offline
Bronco II Engine swap
I have an 89 Bronco II with a 2.9L V-6 and am looking at my options as far as engine swaps. I have considered swapping out with a 300 straight 6, or even a 289... however I am now considering one of the 2.0 EcoBoost as an option. Has anyone swapped one of these EcoBoost into a late 80's Ranger or Bronco II successfully yet? Is there any more info available? Is it even a viable possibility?
Old 05-07-2016, 07:05 AM
mefast's Avatar
mefast
mefast is offline
There's only two swaps I've read about so far. One was into a 1986 Fox-body Mustang. If you search for it on Youtube there's a couple of videos. Also here's a link to a forum that talks about it: 1986 SVO with 2.0L Ecoboost swap - Mustang Evolution
The other was into an 80s Merkur XR4Ti to be used as a rally car: 2.0 Ecoboost to RWD, A Brief How-To
To answer your questions, I haven't heard of any Ranger/Bronco II swaps yet. Obviously that doesn't mean someone hasn't done it yet. As for it being a viable swap, anything is with the right amount of time and money. It will probably cost more than a 300 or 289 swap, but it should be lighter, use less gas (if you stay out of the boost) and be a more modern platform for upgrades in the future. Take a look at those links and if there's more info, I'll try to help you out. Since money is kinda tight at the moment, I'm hoping Ford will release a 2.3L crate engine as well. Considering sales are good for the 2015+ Mustang and the Focus RS is just being released they might be holding off to ensure production lines are stocked first.
Old 03-21-2018, 05:30 AM
karped's Avatar
karped
karped is offline
Aloha all,
Sorry to bring up a dead pony (Mustang ref) I have searched and searched and searched. So from what I can find anyone who has put a 2.0 or 2.3 ecoboost (same block) into a second generation ranger? (1993-1997)
I find myself in a position to purchase a 2.0 crate engine with control pack and T5. the price is reasonable, but the unknowns may require deep pockets. I drive about 100 miles back and forth to work 5-6 days a week. So if it can and maybe has been done 30MPG sounds great; unfortunately I dont have the unlimited pocket to put concepts together.
Someone must have attempted or done the research, please share. time is limited on the purchase of a 2.0 ecoboost crate engine including control pack and T5. Thanks for any inputs.
Old 02-03-2020, 10:17 AM
RetroMod's Avatar
RetroMod
RetroMod is offline
Did you ever put the 2.0 in the ‘94 Ford? I have a ‘93 and I was kicking around the same idea.
Old 04-03-2022, 01:23 PM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
2.0 L EcoBoost Focus ST into a truck
Just getting started on a 2.0 Eco Crate engine into a 1966 F100. Hoping to keep weight under 3600 lbs.
Have secured the new engine along with Ford Racing PCM/Kit found new all for only 2200 so hoping to keep the cost down.
Not my project but I donated the truck to my helper. Hoping to have it on the road by the time he gets his DL 6 mo from now
bigredtruck
01-10-2020 03:31 PM
Trippytim1152
04-24-2017 08:12 AM
HudsonJM
1999 to 2016 Super Duty
12-19-2008 11:41 PM
chadrock
03-01-2001 03:53 PM
Quick Reply: 2.0l Ecoboost Swap?
