Bed-Slide, Powered Hydraulic 8 Foot
Category: Accessories
Price: $1350
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Accord, CRX & pre '92 Civic, '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude, Fit, S2000, Integra & '97-'01 Integra Type-R, RSX & '02-'05 Civic Si, TSX/'03+ JDM/Euro Accord, NSX
Item Condition: TX
Engine: Part suitable for gas truck, Part suitable for diesel truck
Power Bed Slide
Industrial grade
Max. capacity 5000 lb.
Easily operates 2500 lb.
Operates on any angle
Unlimited lock-down positions
Cycle time 15 seconds
Heavy-duty welded tracks
Cam-follower bearings
Able to weld or bolt equipment to deck
Frame mounted power unit
12 volt high-pressure hydraulic system
Center mounted hydraulic cylinder
Long stroke (up to 90% extension available)
Ideal for commercial or heavy-duty applications
Utilizes entire cargo area
Side load-able by forklift
Easy transfer of load surface to surface
Custom applications available
***Hydraulic Powered Bed Slide
Industrial design turns a pick up truck into a completely functional service truck or mobile command post with just the push of a button!
Severe Grades? NO PROBLEM!!
Ideal for heavy-duty, commercial and emergency vehicle applications.
Operating capacity easily carries 2500 pounds. Maximum capacity 5000 pounds
J.M.J.
Thank you for getting back to me. I was afraid it might be gone.
I have been trying to get in contact with the company, but to no avail.
I guess I'll keep trying.
Thanks again. I sure do appreciate your reply.
Clark
Clark
kramttocs
15
02-14-2016 08:05 PM
BlueOvalBud
08-15-2010 10:24 PM
davewild
09-30-2004 02:43 AM
