Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
Location (State/Prov):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Item Condition:
MY 1956 F100 Custom Cab…running project
Old 03-15-2012, 02:26 PM
rockher_man's Avatar
rockher_man
rockher_man is offline
Unhappy MY 1956 F100 Custom Cab…running project
Year: 1956
Make: Ford
Model: F-100
Price: $10000
Mileage: 70000
Color: Red/White
Private or Dealer Listing: Private Listing
Location (State): MI
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Red
Engine: 1970 F100 302 2-bbl
DEARBORN MICHIGAN area…about 2-miles from Ford World Headquarters…right near Greenfield Village!
FOR SALE: 1956 F100 Custom Cab…running project
Due to unforeseen circumstances I must part with my F100 project…
Bring a trailer and cash and it’s all yours….
Selling as a package. Asking $10,000 or best offer…
I have much more that this in the truck AND NEW parts!
1956 F100 --- Red with White top original 2-tone paint
ALL ORIGINAL truck inside & out except for motor & transmission…
302 – 2-bbl AND C4 transmission pulled from a wrecked 1970 F100
...also included is a 2nd C4 transmission that came with the truck...
Fiberglass front fenders…they where installed when I purchased the truck!
PARTS LIST: NOT installed...most NEW in BOXES!!!
2nd set of original rear fenders with spare tire cut-out on driver side fender ---almost NO rust
1970 F100 9-INCH rear axle housing with all brackets removed & cleaned up
Ford 9-inch Big (Torino) Bearing Rear Disc Brake Conversion kit…. rotors are 5 x 4 ½ Ford pattern…
Ford Racing Parts # M-4204-F28A, TRAC-LOC Limited Slip, with 1536-steel billet case caps
ALL bearings & gaskets needed to assemble rear pumpkin….
NASCAR Ford 9-inch 3:89 ring and pinion set ---Back-cut gears!…from
a NASCAR team down south....was told it has ONE 400-mile race on
it............ PERFECT CONDITION!
New Dutchman 28-spline Street/Strip axles & retainers with bearings…NEED axle SEALS!
Extra “hooded” Daytona pinion bearing support without races/bearings
1956 Running boards --- need a few repairs
2nd set of “short” cab-length running boards…I was going to use these to
repair the long ones!
Total Cost Involved Mustang II style independent front suspension with
tubular A-arms and air springs with sway bar…rotors are 5" x 4 ½" Ford
pattern…
No Limit Engineering FAT BAR 4-bar parallel rear suspension with air
ride, includes panhard bar!
Accuair Stage II management system with ride height sensors, key
fobs, air line & cutter, moisture trap,EVERY option available!!!….best of
the best!...this is the MOST complete & wicked system I've EVER seen!
VIAIR 400C Dual Performance Value Pack compressors…same ones
sold by Accuair!...no waiting with TWO compressors...SWEET KIT!
12-gallon 8-port D.O.T.approved air tank for air ride system
Art Morrison Enterprises 2" x 4" square steel tubing for NOTCHES…..
............."bent the hard way”…you can view them here ............
http://artmorrison.com/layout.php?y=frames/&x=framekit
Look for a section labeled: Special Bends Also Available!
ALSO AVAILABLE!…
Probe Industries SRS #10666-030 flat top pistons Net Head Volume (cc) -4.0.
...and...
Clevite Perfect Circle Ring Set: #315-0049-030 1/16" - 1/16" - 3.0mm (std. oil ring)
Early 60’s SMALL BLOCK FORD Buddy Barr/Holley tri power set up!!!
PICTURES HERE...
http://s88.photobucket.com/albums/k200/rockher_man/1956%20F100%20PROJECT/
Last edited by rockher_man; 03-16-2012 at 09:17 AM. Reason: added more parts to list
Old 03-16-2012, 05:25 PM
rockher_man
Exclamation Anyone?.......
ttt...ALL Top Shelf components......
Just waiting.....Man...this is just killing me to have to get
rid of this truck......
I did a lot of research & engineering before I started to
design this build & purchase parts!...
ALL the shopping is done!...just grab your tools & get started...
Old 04-06-2012, 11:36 AM
rockher_man
Exclamation 1956 F100 Custom Cab...
BUMP...........
Old 04-06-2012, 11:49 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Way to much custom work for what I want.
Old 04-30-2012, 12:35 PM
rockher_man
Exclamation NEW PRICE --- $8000.00
LOWER price...
Give me 8K and you got a deal...
I'm loosing big-time here...but I have NO choice!
-=THANKS!...
Old 05-19-2012, 01:11 AM
rockher_man
Exclamation 1956 F100 Custom Cab pickup...
...bump!......
Old 06-17-2012, 04:57 PM
rockher_man
Exclamation 1956 F100 Custom Cab for sale...Michigan!
...BUMP!......
Old 06-18-2012, 01:22 AM
arctic y block
Just way to many mods. If it had the Y block and 3 speed overdrive I would give ya 12k in a heart beat. Think about it bud
Old 07-26-2012, 04:28 PM
rockher_man
Exclamation 1956 F100 Custom Cab project...
Truck is sold!...ALL parts still available...
Email me for prices...EVERYTHING new in boxes...unless
otherwise noted...
-ThankX...
Fords & Whalers
10-31-2016 12:19 PM
20stone
13
07-29-2015 06:51 PM
DutchB100
01-14-2012 08:15 PM
armysoopertrooper
01-07-2011 03:18 PM
bluestang65
09-10-2010 03:45 PM
Quick Reply: MY 1956 F100 Custom Cab…running project
