1973-79 parts
1973-79 parts
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: IN
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
I work a real job so I might not be the fastest shipper but I'll get it to you as fast as possible.
I don't do Paypal and prefer USPS money order.
I only have what is pictured and will try to describe what is in photos as best as possible.
I would like half of new price or less. Make me an offer will probably be best although I'm not packing it up and going to the post office for free. I'm sure you can appreciate that.
Various axles..appear to be 1/2 ton but unsure. Need length and spline you need. $10 each
Steering column tubes and inner tubes. $10.00 each
Power steering hoses...new in box. Don't know what they fit.
Super Cab pads...$20
vent window assemblies.. I have about 8 at $20 each
Steering column harnesses 12 each...$5.00
Various engine perches...$25.00 pair
Rear cab mount plugs and hood springs. Plugs..$2.50 Springs...2.50
Various PS pulleys...need the part number you need. $10.00 each
New gas cap...$20.00
Rear door jamb patch panel...3-4 of these...15.00 each
Firewall wiring clips. Free with purchase
Glove box cover...$30.00
Fuel door...2 of these,1 has small dings...$20.00 each
Hub caps...1 set is pretty good and one has dents. Inner fender to cab supports(30+ of these.)...$25.00/$40.00
Vent housings(bunch available)$5.00
2 barrel..$20.00 and 3 battery trays...$15.00
Ashtrays. 12 + available...$10.00
2 shelves full of headlight buckets. Mostly square but have a few round.Round are as new...$40.00 pair...Square..$25.00 pair
Shift rods/AC brackets/Transfer case brackets/I also have a bunch of poly TC bushings but no steel washers to go with them...$5.00 each
Vent duct...$5.00/uncracked steering wheel...$75.00
40 or so door latches...$4.00
Another AC bracket..$5.00 and oil filter adapters (360 I think)...$5.00
I also have bunch of large trim(probably 2 sets that are good) and a few pieces of narrow trim. I think I have 2 lower fender trim pieces that are new.
I also have rear window trim that is nice...$30.00
Door panels. Pretty decent shape.
Frame crossmembers.
Box of yolks.
Cab mounts...no rubber
2 cab forward harnesses. Looks like its all there.
Box of turn and rear taillight housings. OK shape.
Shelf full of various harnesses.
Side marker harnesses. 10 or so.
Trim pieces.
Various new Ford parts and Spicer driveshaft U bolts sets. Switches/door handles/factory pinstripe kit etc.
Sun visors
Frame crossmembers.
Box of yolks.
Trim pieces.
Sun visors
Various steering wheel covers. Most have some damage or cracked. One of the brown ones are pretty nice...$10-50.00
My original gauge set from 1973. works good...$25.00
Side window brackets(glass rides on these...$10.00
C-6 valve bodies 15 or so...$10.00 each
2 seal kits...axle I believe...$10.00 each
Engine to trans spacers. 6 of each/ 460 to C-6 and 360(I think)$20.00 each
Few driveshafts. One I think is trans to TC highboy. Others ..I have no idea.Cheap
Any alternator and power steering brackets?? If so how much and send pics to jmedina46406@yahoo.com.
Thanks
Thanks
There were a couple of folks interested in some parts along with the alum tailgate trim piece and I have managed to one of their contact info.
Get back to me if still interested.
Tigger!....I know where a 460 F250 is sitting at my local JY and I'm pretty sure those brackets are still there. I'll check for you this week.
