ticking under load, any idea's?
Hey everyone, I was having a ticking problem with the engine under load so I went ahead and did my manifold gaskets. I had a new 5.4 put in my 02 f350 last winter, and at that time I also installed gibson shorty headers. The tech had to plug the egr port with a pipe plug. But any ways, I pulled the headers last month and I used Percy's aluminum header gaskets. I also took the time to wire wheel all of the flanges and the mating surfaces. The one on the ball and socket flange was leaking on the passenger side, so I permanently sealed it with some 1800* epoxy.
The leak seemingly went away for a week or so, but it has returned. I sprayed down all of the mating surfaces with soapy water, but I can't find the leak. It only happens when accelerating or when i downshift to go uphill.
So, at my whits end, I went to try and retorque my spark plugs. I've done half of them so far. Havn't driven it yet, but i was curious as to others thoughts on the subject. more idea's?
this leak cannot be heard at idle, nor at any RPM while in park or neutral. It is only apparent when driving. definetly sounds like an exhaust leak to me. any opinions are welcome
i will have to try that idea. i cannot remove the pipe plug to re-seal it, it's pretty well in there. the joint was packed and completely coated with an epoxy made by Por-15 good to 1800 degree's, i don't think it's there. is there a slight possibility that the ticking is acutally in my wheelbearing/wheel joint? i heard some noises from it the other day. im going to take it for a drive to work to see if i can hear anything else...
check your headers. also, just because you wire wheeled the surface doesn't mean that the surface is true. Headers are notorious for warping and leaking. aluminum gaskets are a good start, make sure they're torqued to spec, warm it up and cool it down a few times (driveway, not highway) and retorque them down. I recommend locking header bolts.
Ticking can happen under load. back pressure build up only shows when there is a heavy exhaust flow. how's your cat and muffler? a plugged up can can cause the problem to show up worse...
that is a good point about load. i have been having this problem that on occasion when i rev the engine and let off the gas the RPM's will drop and the truck will almost stall out. this also happens when shifting into reverse from drive. thought it was the IAC, but I replaced it and the problem is still present. so I suppose back pressure(yes it is a myth) could be a contributing factor in my many problem.
I have also considered the possibility of internal engine problems on a fresh rebuild. I purchased this motor through PROformance and it has performed wonderfully...
i may just have to ignore it until next spring... unless anyone wants a mint f350 with 10k on motor and 107 on the clock
just an update: it's kind of cold up my way in ct this morning so i plugged up my tail pipe with some rags and started up the truck. the usual cold morning white exhaust poured out of the many holes in my muffler, but there was none to be seen anywhere up front near the engine. which is a great sign to me. the ticking was more pronounced at idle to the point that i could hear in from both headers. this leads me to believe that there is simply a flow inconsistancy somewhere in my headers. this leaves either the pipe plug in my egr port, or the fresh gaskets i installed in my headers. i think i will rule out internal engine problems for now, but i will be adding some lucas oil stabilizer as well as switching back to motorcraft oil on my next service change.
thanks a lot guys!
thanks a lot guys!
yeah one of my friends from ashford is a member on the board. i'm sure ive spoken to alot of local members a time or two, you meet a few people here and there when you work in a parts store.
