Gas tank size
Gas tank size
How big is the gas tank on my 98 E250 5.4 standard cargo?
The manual says 35 or 37 gal depending on how you read it. I ran the tank to the gauge sitting on E, filled the tank all the way up, and it took 28 gal. I just don't believe that there is 7-9 gal reserve at empty? Most vehicles are maybe 2-3 gal on E.
Am I missing something or is the gauge wrong?
28 gallons is about the max I can stuff into my '00 E250 with the same 5.4--maybe 29 but that's after filling it past the advisable point of first click off of the pump handle. I don't know how the manual would figure its 35 or 37 since your experience and mine suggest 28 is about the max.
Two thiings though------don't run your tank that far empty very often, hard on the fuel pump as it'll over heat. Don't add too much fuel after the first pump click off as the tank needs venting and too high in the filler neck could interfere with that.
Is this the Ford original owners manual?
I don't get it? I could drive another 100 miles when the tank is on E before it would run out of gas? is that crazy or what?
Not sure if you "don't get it?" but I wouldn't count on "another 100 miles".
The 35 gallon capacity tank allows for: expansion space, reserve capacity & sump space below the fuel pump pick up.
The needle on the gas gauge can move past the E or the F. The gauge isn't calibrated to lab accuracy.
Suggest if you want to know if you "could really drive another 100 miles when the tank is on E" or if it's "crazy or what?" that you run the obvious test.
Carry a can of gas. Then intentionally "run out of gas" after choosing the point at which you think "the tank is on E" exactly & noting odometer reading. When your Econoline sputters to a stop record the odometer reading & subtract 1st reading. This will tell you how far you "could drive" after "the tank is on E". Simply pour in the can of gas you're carrying to get going again.
The tank's size is 35 gallons, but you can't fill it, because the top gets full of vapor and blocks the pump. If you could put a larger capacity EVAP system (Charcoal canister, lines, larger valves at the top of the tank, etc), re-program the computer, and fill it with engine running -- you could fill it more.
The problem with force-feeding is that the fuel shutoff (toilet-plunger) valve at the top can be overwhelmed, which will allow liquid through, which can saturate the Charcoal canister.
Distance doesn't matter -- if that Toilet Plunger (fuel shutoff) Valve atop fuel tank does not close the flow, it doesn't take much liquid fuel to run thru the 1/4" line and fill the coffee can Canister.
When you can't fill the tank, the fault usually lies with that Valve, which is supposed to release vapors from the tank to the canister. Force-feeding causes malfunction in the EVAP system too.
These plastic valves are cheap, but tank needs to be lowered to get to it.
