1985 Bronco mud Truck
Year: 1985
Make: Ford
Model: Bronco
Price: $1350
Mileage: 86000
Color: flat black
Private or Dealer Listing: Private Listing
Location (State): IN
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Black
Engine: 351
85 Bronco mud truck. Flat black, lifted. The rear top has the sliding windows. Body is typical for old ford truck. Both doors were replaced (passenger side is damaged but still opens and closes). Tailgate has no visible rust.
351 crate motor around 80k miles with MSD ignition, edelbrock carb and headers ~ $450
I have a video of it running but it doesn't idle well, most likely the idle jet needs cleaned
C6 Automatic transmission (for 4WD) ~ $200
42" x15.5" super swamper tires on 12" rims. 2 are in great shape, 1 is decent, the last tire is worn but still has the side lugs so it's still ok in the mud ~ $400
8" suspension lift with a 4" body lift (rear block, front new coil spring with drop A-arm brackets and drop pitman arm). I believe it's a sky jacker brand ~ $400
9" rear axle ~ $150
I'll let the whole thing go for $1350 (cheaper than parts). It's worth a lot more, but I have too many toys and don't feel like fixing it.
the XFer case doesn't shift into 4x4 and I broke the rear knuckle in the double cardon joint so it won't move on it's own. Also, the steering drag link is bent but I have a replacement to put on it. It's slightly toe'd in. Windshield is cracked. Has a very massive I-beam for a front bumper.
call 812-801-6172 or text or email ndawg@lavabit.com
