1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Ricon 6 way seat
Old 05-15-2019, 07:03 PM
jimbomitch
jimbomitch is online now
jimbomitch is starting off with a positive reputation.
Originally Posted by GUNNERMATE View Post
Ok, thank you.
No problem and good luck getting it resolved. My seat bases are older but I doubt Ricon would change motors. Did you try tapping on the motor? My motor recently stopped working so I gave it a few taps and it started working again. I bought a few spares cheap off eBay.
  #32
Old 05-15-2019, 07:39 PM
GUNNERMATE
GUNNERMATE is offline
GUNNERMATE is starting off with a positive reputation.
It still works. The dealer of coarse said it was moving slow and was going out. All three functions are shorting out, and my seat is wobbly. I some times have to wiggle the switches to get them to move. There is a short or bad ground I would think. He said I need a swivel plate also. A friend of mine said I need the bronze bearings to fix the wobbly. When it swivels back to the driving position it does not turn of on its own like it supposed to do.
Old 05-15-2019, 07:59 PM
jimbomitch
Sounds like you have a low voltage or ground problem. The switches rarely go bad and either work or don't. The motors last a long time, unless you're really heavy.
Old 05-15-2019, 10:41 PM
GUNNERMATE
Nope only weigh 160
Old 05-16-2019, 03:46 AM
maples01's Avatar
maples01
maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Check to insure it's grounded good, the lift arms on mine, somehow the wiring to the seat swivel was cut by the mechanism, rendering my chair immobile. I plan to be picking up another power seat base in the morning, with luck it'll work without work, not expecting it to for what I'm paying for it. BTW cheap window motors have plastic gears, I've had them apart, wont last as long.
Old 05-16-2019, 07:34 AM
jimbomitch
Nope only weigh 160
That's about what I weigh. My one van is a 93, and so is the seat base. I have replaced the forward/rear motor one time. All the motors should be fed by one wire, check that and the ground.
Old 05-16-2019, 07:42 AM
jimbomitch
True, some of the window motors have plastic gears, the ones that I linked have steel gears though. Regardless, it's pretty remarkable how long these motors last given operating a window verses sliding a person back and forth.
Old 05-16-2019, 11:58 AM
maples01's Avatar
maples01
maples01 is offline
Yeah, I've had mine for 16 years, was used when I got it, the power sliding door setup looks really old, gonna guess inside a door operating windows corrosion sets in due to moisture. The stop on my top turntable bent, it now runs off of the gear when turned and spins, I need to find a way to fix that, anyone else have that issue?
  #39
Old 05-16-2019, 02:35 PM
jimbomitch
@Maples:. Is your base a Ricon? My old 93 does the same thing, so far really hasn't been an issue. I try to release the switch before it comes past the gear.
Old 05-16-2019, 05:21 PM
maples01's Avatar
maples01
maples01 is offline
Yes it's a ricon, I just don't want to strip the teeth off of it.
Old 05-16-2019, 06:36 PM
GUNNERMATE
Turns out my I need a new swivel plate. 4 of the teeth are broken off it. Ricon lists it for $135. Anyone know what this part is from. I'm sure Ricon doesn't make it.
  #42
Old 05-17-2019, 07:17 AM
jimbomitch
That swivel is more than likely Ricon
Old 05-18-2019, 04:10 AM
JWA's Avatar
JWA
JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
I really have no experience with these seats but it makes sense if its part of something Ricon sells most likely it won't be available anywhere else. If its from an outside vendor they'd not offer it separately and risk losing Ricon's business.
As much as any of us hate over spending for parts sometimes there's no choice.
Old 05-18-2019, 08:47 AM
jimbomitch
Only other option would be to have one fabricated, which would probably negate any savings.
Tom
75
02-16-2018 05:50 PM
riconeal1956
Ranger & B-Series
11-19-2017 09:28 PM
riconeal1956
11-18-2017 08:06 AM
Brian L in AZ
09-04-2017 10:42 AM
jeffreyclay
04-12-2016 06:54 AM
Quick Reply: Ricon 6 way seat
