Stirring the pot
Old 07-13-2019, 09:29 AM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
Take a look at the ram 2500 "megacab" with the not so mega payload capacity....not sure this is a productive conversation as the truck should be equipped to the trailers being towed.
Old 07-13-2019, 10:28 AM
countrycar's Avatar
countrycar
countrycar is offline
countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.
It's not the towing part that gets folks in trouble, it's the stopping part that seems to cause them problems.
Old 07-13-2019, 02:06 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is online now
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
OK guys, After 20 years on these forums, two fifth wheels and three super duties I have learned that anyone who starts or contributes to a thread about weight is a glutton for abuse. So here is my response to all the weight mommies.
Old 07-13-2019, 02:18 PM
StanleyZ's Avatar
StanleyZ
Originally Posted by senix View Post
In the above I am over the ford door cert which means nothing. Am was within my axle ratings. I did adjust my truck registration to 12K though.
Sennix, do you remember the first round of super duty turbo diesels. I thought you had one. I had a 2001 F250. Fords tow rating for fifth wheels for both 250 and 350 trucks was "20.000 lbs less the weight of the truck". So if applied my short f250 could tow more fifth wheel than a long bed dually.
Old 07-13-2019, 02:20 PM
StanleyZ's Avatar
StanleyZ
Originally Posted by djousma View Post
You are stirring the pot for no reason though, unless you want to discuss 5th wheel towing with a 1/2 ton truck. Scott has it right. The door sticker GVWR for the truck is a meaningless DMV number for plating purposes in many states. What matters is the Front/Rear GAWR on that same sticker, combined with the load capacity for the tires you have on your truck. Never exceed the lessor max capacity of those two, period.
Absolutely correct, And the axle ratings are tire specific. Get better tires carry more. Hard to get enough stuff on a truck to bend an axle housing but over loaded tires have and will blow out.
Old 07-13-2019, 02:50 PM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Yes I did. Somehow we managed just fine.
Old 07-14-2019, 03:50 PM
Overkill2's Avatar
Overkill2
Overkill2 is online now
Overkill2 is gaining momentum as a positive member of FTE.
Yesterday, I was driving interstate 90 to go to Rochester for a family party. I started approaching a camper that was swaying back and forth once in awhile. It was a decent size, maybe 20 feet or so. Pulling it was a Mercedes SUV that was squatting in the rear and the front end pointing up. Looked like two yuppies with New Hampshire plates. He had the snap on mirror extensions as he truly needed them.
As I got closer, I thought of this thread. I grabbed my phone but dropped it so I couldn't take a picture. There was no way that SUV should have been towing that trailer. Way overloaded. I definitely wanted to be nowhere near them...
Old 07-16-2019, 11:54 AM
Alleydog's Avatar
Alleydog
Alleydog is offline
Alleydog is starting off with a positive reputation.
StanleyZ is correct. Getting higher rated tires will increase the load you can carry.
Old 07-16-2019, 06:37 PM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
As long as you dont exceed RAWR.
Old 07-16-2019, 09:31 PM
StanleyZ's Avatar
StanleyZ
I think that was my point. Thr rawr is tire dependent. Increase tire rating and rawr increases. Of course the numbers on the door jamb donít change. And I guess to cover all the bases yes there is probably an upper limit at which the axle housing or wheel bearings or the axles them selves would fail. But anyone with walking around sense will not load to that level.
Old 07-17-2019, 05:33 AM
djousma
djousma is offline
I see what you are saying. My understanding, which may be wrong, is the RAWR on the sticker is the max rating for the axle itself. Inferior tires, would reduce that number based on max tireload for each tire. Maybe someone can chime in on that.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
