Transmission 19S07 Recall results!
Old 05-20-2019, 06:12 PM
Fat Ford Boy
Fat Ford Boy is offline
Fat Ford Boy is gaining momentum as a positive member of FTE.
Have your dealer run a Oasis. If its listed they should be able to do it without the letter !!!
Side note: On some occasions there may be some harsher shifting than before. BUT, the vehicle/computer will learn YOUR driving style, and adapt the shifting to the way you drive.
FWIW
  #32
Old 05-22-2019, 12:06 PM
Skoiv's Avatar
Skoiv
Skoiv is offline
Skoiv is gaining momentum as a positive member of FTE.
Now after several weeks, I am happy to announce the truck is shifting very well and back to normal. Just needed a little "learning" I guess. All good.
Old 05-22-2019, 12:20 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
steve(ill) is a name known to allsteve(ill) is a name known to allsteve(ill) is a name known to allsteve(ill) is a name known to allsteve(ill) is a name known to allsteve(ill) is a name known to all
There is something wrong with the new software if it SLAMS into gear and then takes 6 WEEKS to "LEARN" how you are driving the truck... Software should be flexible to MODIFY to fit your driving, but should not be 1000% OFF to start with.. Somebody screwed up I think.
Old 05-22-2019, 12:49 PM
Skoiv's Avatar
Skoiv
Skoiv is offline
In those three weeks I have only driven it a handful of times. Sorry if that was misleading. No one screwed up.
Old 05-22-2019, 07:46 PM
steve(ill)'s Avatar
steve(ill)
No, you are not the only one that has had troubles... I would expect MINOR changes in shift pattern, but nothing like what has been reported.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
