1992 - 1997 Ford F150 Truck Steering Column Shift Tube Assy with Bushing SET
http://www2.1aauto.com/_include/gui/logo_large.gif
http://www.1aauto.com/img/ucart/imag...00094/main.JPGhttp://www.1aauto.com/img/ucart/imag...4/middle_1.JPG CLICK LINK BELOW FOR CURRENT PRICING 1992 - 1997 Ford F150 Truck Steering Column Shift Tube Assy with Bushing SET This replacement 4 piece steering column shift tube assy is just what you need to get your vehicles steering coulmn in good working condition again! As this assy wears, it causes the sticky and wobbly feeling in your shift lever. Also, if exposed to moisture, this can cause the assy to rust up causing the normal smooth shifting motion to become hard to move. Features: Located in the center of the steering column ( See location diagram) Steering column will need to be disassembled to replace parts Consists of the following pieces: (1) Shift Tube (1) Selector Plunger (2) Selector Bushings Replaces dealer part numbers: F3TZ 7L278 A, F3TZ7L278A, F3TZ 7212 A, F3TZ7212A, 1F1Z 7212 AA, 1F1Z7212AA, F7DZ 7R264 AA, F7DZ7R264AA Built to strict quality control standards Direct replacements Fits all models with or without tilt steering Correct for models with Column Shift Does not fit models with floor shift This Steering Column Shift Tube Assy is a great replacement part and provides a good cost savings over the price of dealer parts. This part replaces: OE #: 1F1Z 7212-AA, F3TZ 7L278-A |
