right on you had us worried:)
Originally Posted by ShastaLakeLndscaping
(Post 9378272)
100% correct. I failed to inspect the tube close enough, it is rotted by the manifold and the stick was not going in all the way. So I went to the dealer and bought the part, it was $20. The oil is now at the correct level after removing the 6 extra qts. I just went ahead and changed all the oil and filter. Thanks for everyone's help!!
This is the only explanation that makes sense--I was gonna accuse you of leading us on with a line of BS...hope you're recycling the old oil...I'd probably save it for my lawnmower or give it to a friend with a junk car. Good luck, George |
It amazes me that the oil pan could hold 12qt with out spilling on the ground via the hole in the dipstick tube.
Originally Posted by YoGeorge
(Post 9378471)
Good deal...you really had me confused too, wondering if you had an oil-drinking tapeworm living inside your motor or something :)
Originally Posted by BURNSTOUGHFORD
(Post 9378613)
What is most remarkable is that the engine was not damaged:confused: If anyone had any doubts as to the durability of the 4.2....you can put your mind at ease:-jammin :-drink |
(Post 9378918)
My first presumption was the tape worm. I would never put used oil in my mowers I rely on them to make a living. The last zero-turn I bought was $6000, the truck was $1500, if anything it'd be vise versa :p
I'm glad you got your truck sorted out; you really had me scratching my head. George |
Originally Posted by ottawaguy
(Post 9378930)
...after my last post, I was thinking the same thing.
(Post 9379056)
I wasn't thinking about *your* kind of lawnmower. The one I've got, I found down the block by the curb on trash day--looks like one of the neighbors decided to get a lawn service. I cleaned out the gas tank, sharpened the blade, and it's been great for 2 years. Actually, I have some nice Valvoline Synpower in it because I had half a quart in the garage...didn't even change the spark plug yet.
I have the same problem. .
Originally Posted by MikeB 88
(Post 9377529)
I wonder if you have the right dip stick for your engine.
Problem solved!
Originally Posted by Lramgon
(Post 19587478)
I changed the oil, added 6 quarts, and no sign of oil in the dipstick. The oil gauge shows normal pressure and the warning light goes off when I start the engine. I bought a dipstick for the same engine (4.6L) in a junkyard, and still the same problem. There's no sign of oil leak or burning.
No Oil
(Post 9376874)
Hello everyone! About a month ago I bought a 2000 f-150, 4.2l v6, 185,000miles, automatic, reg. cab, short box. When I was looking it over I checked the oil, it was a little low but black and surely used, so I assumed it didn't have a leak or use too much. The day after I got it I changed the oil using gastrol 5w-30 and a fram oil filter, the oil level was fine, I checked it again the day after and it was also fine. Today, after being driven 1,000 miles I decided to check it, and there was not a drop on the stick!! :( So I added 5qts. checked it and still nothing, added 1qt. drove around the block, and when I got home there's still not a single drop of oil on the dip stick, how can it be completely blank after adding 6qts.?! I park it in the same spot everynight, and theres no oil where I park. Theres no visible leak around the filter or drain plug. The anti-freeze and transmission levels were both fine and continue to be. The dip stick tube is into the engine block as far as it should be, and the dipstick goes down good, so I dont think the measuring method is mis-construed. Any help would be greatly appreciated!!!
